Sony TV Trinitron is on standby
Sony HD T V model KV 34 HS 510 one of grandkids played with remote control and I dont know what they did but since that time when you turn TV on from remote it shuts off after turns on immediately without any picture and we have cable It is on standby light on TV Sony TV model KV 34HS510 Sony Trinitron.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Unplug TV for 10 minutes and replug back in AC power source and turn ON TV.
    Hope that will solve your TV problem.
Standby light flashes tv wont turn on
Posted on Jun 01, 2009
  • 790 Answers
Hi
Maybe the child lock is activated and you need to hit the pass code..
Thanks!
Posted on Apr 12, 2009
SOURCE:
I have a tv Sony Trinitron XBR. It does not turn on; the LED red light blinks 7 times.
Common problem on those. It has deflection stopped. I.C. on deflection board. Need shop to repair.
Nov 23, 2014 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I can't figure out how to get my Sony KV-34HS420 to factory settings!
Hello
To reset your tv to factory settings do the following:
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
Jan 23, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My tv sony wega dont turn on an the standby light blinks 16 times model KV-32FV310
Hello
Standby light on Sony TVs blinks 16 times is abnormal I thiks. It may come up to 8 blinks or so. You jsut switch off the set by AC mains switch at the front panel, switch it again with it and count the exact numbers. Never switch it On_Off by remote hanset.
If it happens even after this process, you just do the following
Press the following button on your remote control as stated
"Display"_"Channel"_"5"_"Vol Minus" [not plus] then "Power".
You may get "OVP" "OCP" "V STOP" etc displayed on the screen.
Just report the result to me through Fixya. Ok.
Nov 04, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My will not work with the remote any longer. I replaced that. When I manually turn power on, it takes 3 or 4 times before coming on. Then, it will turn off after about 30 seconds. ANy ideas?
There is an infrared sensor inside the tv to receive infrared signals transmitted by the infrared signal generating light emittin diode fixed on your remote control. Either the sensor inside the tv or light emitting diode in the remote controller faulty, remote function will not work. For manual operation troubles, check the wall power socket of plug of the tv is faulty, loose contact etc.
Oct 13, 2010 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Television will not turn off, move volume or etc..
if does not solved the problem by unplugging it for long time, thetrouble is hold down, mostly in sony defective resistor is causing holddown.as far as i know ..evn i had same problem wid my sony wega few mnths b4..gudluck.
My-SIGNATURE:::WATCH TV SHOWS ONLINE IN HD including your fav shows ,hells' kitchen,America's next top model ,Oprah winfrey episodes and lot more
Jun 23, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-34BR800 TV intermitent startup problem Have to try remote multible time,will finally turn on.
try cleaning small lens on end of remote and receiver window on t-v (usually a small plastic covered window- on the front). if still have problem- could be you need new batteries in remote, or button on remote needs cleaning. a q-tip and some rubbing alcohol (91% or better!) use very little alcohol- just damp! may have some crud around button.
good luck!
Oct 06, 2009 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Standby lighy blinks tv won't turn on
error code 4 is vertical deflecton failure . replace the vertical deflection ic. and the electrolytic capacitors in the vertical circuit. Or if you are lucky just resolder the vetical IC and resolder th horizontal section too.
Sep 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Intec G8621 Wireless Remote Control For Xbox 360 - Need Codes
Does any one know the code for the PHILIPS model 40PFL7505D/F7 HD
Mar 08, 2009 | Sony KV-32FS13 TV
Televison & Video Logo
1,014 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
