Question about TallyGenicom Tally Print server RS232 serial Print Server
Genicom 4440 XT - will not print, has a code 491. What does that mean?
FORD FOCUS CODES 136; 491; 1131
You might want to search for more info online - - code 136 and 1131 are for O2 sensor problems. Code 491 is for secondary air injection flow out of range. The EGR system controls the emissions in the exhaust by injecting air into the exhaust. The computer is not "seeing" the O2 sensor(s) switch back and forth and there is a problem with the secondary air flow. The air flow problem could cause the other two codes. I think the 491 and 1131 are Ford specific codes.
Jun 25, 2012 | Ford Focus Cars & Trucks
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
I have printer genicom 4440 xt and have not a driver i want a diver for this printer thank you
Just try using a generic print driver in windows. This driver will send standard ASCII code and the printr should allow you to print standard text. try it.
Apr 10, 2010 | Tally Genicom 4440 Printer
Genicom 4440 is 15 years old and is used to print invoices with bar codes. The bar codes are not passing USPS regs. They are curved and were not like that years ago. Can the print head be cleaned or...
Yes to both questions. This printer has 3 print modules. you can try swapping the right side for the left side module or vise versa and see if the problem changes. if it does then you should replace the bad module.
Jan 31, 2010 | Tally Genicom 4440 Printer
How do you clear print buffer on Genicom 4440XT printer?
The buffer on the 4440XT can be cleared by powering the printer OFF and then back on again.
You may however find print jobs are held in the spooler on the computer system and will simply reprint when you turn the printer back on again, you will need to check the spooler on the system also to delete any unwanted print jobs.
Nov 17, 2009 | Tally Genicom 4440 Printer
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
May 07, 2009 | TallyGenicom 2265+ Matrix Printer
Okidata C5200 error 491
You say you have checked properties etc but have you selected mp tray from printing preferences in the driver. Remember the driver overrides the printers own settings.
Sep 24, 2017 | OKI Office Equipment & Supplies
Wake up from energy saver mode
the menu where you set the time once you've scrolled though all the time options will give the option of disabling it.
Jul 10, 2008 | IBM 6400 Matrix Printer
Telly genicom printers
What do you mean picking papers. Do you mean feeding the paper, or printing with certain types of paper?
Aug 09, 2007 | Tally Matrix T2280 Printer
TallyGenicom Tally Print server RS232 serial Print Server Logo
55 people viewed this question
Top TallyGenicom Computers & Internet Experts
Alun Cox
Are you a TallyGenicom Computer and Internet Expert? Answer questions, earn points and help others
