Question about Dell 810 All-In-One InkJet Printer
Networking I can not net my Dell 810 from my main PC to a laptop, both running versions of XP
  • Anonymous May 31, 2008
    I still can not connect/run my dell 810 printer from my laptop which is running XP home edition. I am not on a wireless network - cable connected to main computer
    Thanks
    Alan
    Genius:
  • 1,142 Answers
    Please be specific so that i can provide you simple solution to get your printer working, tell me how exactly the connection is
SOURCE:
Dell latitude D830 will boot up to windows XP screen and then will freeze. reboot and comes up with gray screen. F2 during booting does nothing. What could it be?
Turn on the Laptop and as soon as you see the Dell screen click F8. Then click on Safe Mode Networking. Once you log into your account you will then go Superantispayware.com and download the portable version. Then run a complete scan. Then remove any viruses it picks up
Feb 05, 2013 | Dell Latitude D600 Notebook
My dell 810 printer will scan but won't print, i have recently bought a new dell laptop, do i have to change some settings on it?
IF THE LAPTOP YOU HAVE BROUGHT IS A DIFFERENT OPPERATING SYSTEM THEN INSTALL THE SOFTWARE THAT IS RELEVANT TO YOUR OPERATING SYSTEM. (IE XP, VISTA ,WINDOWS 7)
Aug 18, 2010 | Dell 810 All-In-One InkJet Printer
How do I get my Windows 7 laptop to add printer from my Windows xp PC. Just purchased a Dell laptop with Windows 7. My PC has Lexmark 7300 printer, I cannot get the laptop with 7 to add printer with my pc...
Lexmark do not provide a driver for this printer for windows 7.
The latest version is for XP only.
http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X7350#1
You could use the XP as a printer server, i.e. it would interface to the printer, but accept documents from a Windows 7 laptop.
This web page shows how to set up the XP printer as a network printer on the network as windows 7 resource.
How can share printer on Windows 7 x64 with Windows XP x86
Dec 19, 2009 | Lexmark X7350 All-In-One Printer
I got a new computer and it does not have the download for my Dell 810 on it. I no longer have the cd that came with the printer. Do you have a short cut to download so I can use the printer? Thanks
Just copy and paste.
Hope this helps.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PRN_ALL_A810&os=WW1&osl=en&catid=&impid=
Sep 21, 2009 | Dell 810 All-In-One InkJet Printer
Dell dimension 4600 ethernet port/driver issue
The link for the drivers is ftp://ftp.us.dell.com/network/R67150.EXE
If runningit directly does not install the driver go to Device manager and right click on the ethernet adapter and update the drivers. Use the manual method and browse to c:\dell\drivers\R67150 for the driver location. also the latest .netframweork is downloadable from here.
Aug 07, 2009 | Dell Dimension 4600 PC Desktop
How can i get Network drivers for windows 2003 server on Dell studio 15 laptop
Hello
first you need to share it from the server example d:\data
then you need make a connection to your srever from your dell.
example
If the servername is "BOSS" then you should click start run and write \\boss on your dell computer.
If the server and dell is on the same net it gonna popup a window.
right click on the "DATA" catalogue and "map network drive" use a letter example Z: and mark the square reconnect when windows start or something like that. then you gonna find this on your "My computer"
Jul 10, 2009 | Dell Studio 1535 Notebook
I have a Dell and net adapters doesnt work
Uninstall and reinstall LAN drivers and Broadcom drivers.
Press Windows key and R key simultaneously to open Run Window.
Type "devmgmt.msc" and click on OK.
This will open Device Manager.
Click on "+" sign next to Network Adapters and right click on the network adapter and select Uninstall.
After uninstalling right click on Network Adapters and select scan for hardware changes.
This will reinstall the drivers.
Sometimes windows prompts you to restart the computer to reinstall the drivers automatically.
You can even reinstall the new LAN and Broadcom drivers from your Dell website provided they have new version of these drivers.
After reinstalling the drivers, check if the adapters work.
If the adapters still don't work, the issue could be with the hardware.
You may even try with recovering your PC using Dell Factory Recovery.
Before performing Recovery, take the backup of your hard disk as the Recovery process will restore your notebook completely to factory settings.
Jun 15, 2009 | Dell Latitude D600 Notebook
Dell inspiron 1300
go to the site on net and down-load bios and chipset of the system then installed it on the system.
May 29, 2008 | Dell Inspiron 1300 Notebook
Vista to XP downgrade
If you did a clean install of Windows XP Vista has nothing to do with this problem. I infrequently have problems with Dell drivers not working but when I do its because I've installed the wrong ones. I have gone down the wrong troubleshooting path several times because the driver said it installed correctly..... I noticed that when you go to the Inspiron 6400/E1505 download page (http://support.dell.com/support/downloads/index.aspx?) you have the choice of selecting drivers from lots of OS versions including both 32 or 64 bit versions of XP. I would verify that you have the write driver versions and try again. Another alternative is using the drivers and tools CD that typically comes with a Dell. You can run that and it should have XP drivers. If you don't have the disk you can also try getting the network card running, connect to the Dell site and running their driver ID wizard to ID the drivers you need. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 20, 2007 | Dell Inspiron 6400 Notebook
Dell 810 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
