Keyboard problem my letter T in my laptop wont wor. everytime i turn my laptop on it makes a beep sound that wont stop until i press on enter several times.
  • 1 more comment
  • laloht Dec 01, 2007
    i am having problem with my laptop HP compaq nx9010, when i turn on my laptop it gives a beep, its automatically entering y key. if i remove key board also its happening. when i remove touch pad then its fine, is it a motherboard problem?? how can i solve this problem, plx help me any body
  • VJ12 Dec 11, 2007
    When ever I boot my compaq presario laptop it makes beep sound for longtime and later I see 'q' letter getting hanged as it continues typing 'q' letter and it stops on click of Enter key and q key stops responding. It happens every time i boot my laptop Pls help
  • yoaf Oct 03, 2008
    i have Acer Extensa 5620 Vista
    1. When i power on the laptop
    it have continous beep sound on screen that shows 'press F2 to get
    setup or F12 to get Boot sequnece' and when i press Enter key it
    initialize operating system
    2. when I open Mycomputer or any folder it shows me with a speedy
    maximze and minimize blinking display but other application run normaly
    ps Help me out it was normal before only the one key"p" doesnt work
Tengo un problema con mi computadora esta tiene bloqueada la clave de labios y no puedo utilizarla si alguien sabe una solucioin por favor le pido me ayude, por favor hace mucho que no la puedo utilizar mi email es migoo170@hotmail.com
Posted on Oct 24, 2008
  • 89 Answers
It is difficult to give you a solution without a brand and model number. However, you can find a new keyboard on the internet for your laptop and installation is usually simple. That will solve your problem.
Posted on Sep 10, 2007
How do i stop the beep everytime i hit a letter
1.Were there any hardware or software changes made on the computer prior to this issue?
2.Who is your computer manufacturer? Are you using a laptop are a desktop computer?
3.What is the make and model of your keyboard?
Perform the steps mentioned below and check if it helps.
a)Click on Start and type devmgmt.msc in search box and hit enter.
b)Select View (at the top of the screen) option and click on Show hidden Devices.
c)Click on Non-Plug and Play Drivers right click on Beep option and click on properties.
d)Click on driver tab and Disable it.
e)Click Apply and ok.
Try different keyboard on your computer. If it is working fine when connecting a different keyboard, the issue might be with the keyboard.
Hope it helps.
Jan 07, 2018 | The Computers & Internet
My alienware m11x has this problem everytime i turn it on it beeps and doesnt stop beeping lights comeup and fan but no display either
* Make sure the laptop is using the AC adapter
* Turn on or restart the computer
* When the Dell logo appears, press F12 immediately. If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop, and then shut down the computer and try again
* Select Diagnostics from the menu and press Enter
* If a failure is detected, the computer stops and beeps, press Y to retest the component that failed
Oct 14, 2013 | Alienware PC Systems Computers & Internet
Keyboard beeps when any key is pressed eventhough all sticky key and filter key is turned off
get a cheap usb keyboard, plug it in and see if same issue shows
if it does, your keyboard on laptop is shot
if the usb keyboard does same thing, it's a more major issue on motherboard
anything spill on this unit by chance?
Jun 13, 2012 | MSI Computers & Internet
Letter t is not working could it be due to software issue
You have an internal connection issue inside your keyboard, the easiest option is a replacement keyboard, these can be found on ebay, just search for your model number.
Mar 06, 2012 | HEWLETT-PACKARD Computers & Internet
Acer extensa 5620 starts booting with a beeping sound . any way when some keys are pressed the beeping sound stops and the copmuter performs normally.
This is likely caused by a stuck key somewhere on the keyboard. A computer's BIOS will beep repeatedly if it is receiving too much input when booting, like if you were holding down a letter key while starting up. By pressing other keys you're probably breaking the repeating input which is why it stops beeping and works normally.
My recommendation would be to check all of the keys on your keyboard to see if any of them are stuck down or generally sticky, or if any of them appear damaged in any way.
If they are not, it may be a problem in the connection from the keyboard to the laptop's motherboard, which would likely require the laptop's keyboard to be replaced, which can be a tricky process. I definitely advise consulting a professional to do a repair like that.
Hope this is helpful!
May 09, 2011 | Acer Extensa 5620 Notebook PC
My k'board is not responding properly I have to hold the key down to get it to type a letter. Help. Each time a key is pressed it makes a ''blip'' sound also. Strangely the k'board worked fine when logging...
You need to turn OFF your Filter Key option for beeping key strokes.
1) Go to START > Control Panel > Accessibility Options
2) In the window Accessibility Options > select the tab Keyboard
3) Under frame FILTER KEYS, select button SETTINGS
4) In the window Settings For FilterKeys > under NOTIFICATION >
5) UNcheck "Beep when keys pressed or accepted".
Sep 25, 2009 | Computers & Internet
Keyboard letters opkbnm not working on dell inspiron laptop,
Sounds like keyboard failure, replacement keyboards are around $20 on Ebay
Jun 23, 2009 | Computers & Internet
Letter
The letter "H" on your keyboard got stuck and it's like pressed down all the time. You can pop out the key then clean it. If the issue is resolved, you should not hear the beeping sound anymore when you boot up the unit. Or better yet, if your under warranty, contact Toshiba, 1-800-457-7777 and they'll be blad to repair your keyboard.
Hope this helps.
Sep 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Laptop problems.......................Sony Vaio PCG9L2P
Using a USB keyboard should pose no problem, just plug it in and it should work fine.
The other problems are difficult to diagnose without using tools to work on it.
First make sure you don't have a stuck key.
Checking whether the laptop keyboard/cable is seated correctly or removing it and reseating it may stop the problem.
If you do this be sure the laptop is not plugged in and the battery is removed.
I'm not familiar with sony laptops though most laptops if you remove the panel with the power button, sometimes held on by screws beneath the battery, you can remove two or three screws to remove the keyboard.
Doing this may solve your problem though I've never seen such a problem before. You either have a bad keyboard or motherboard.
I would guess the keyboard first since C does not work and you have to press Prt Scr/Print Screen to make it boot to stop a ringing noise. It kind of sounds like you may have a stuck key and since C does not work it would most likely be C that is stuck.
Sep 09, 2008 | Sony Computers & Internet
Computers & Internet Logo
347 people viewed this question
Alun Cox
David Payne
David Payne
