Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Hara drives not detected
I m hving my compaq nx7400 notebook,i m reinstalling windows xp pack-2,i m getting error that 'INSTALLING DOES NOT CONTINUE ,B'COZ HARD DRIVES NOT PROPERLY DETECTED OR NOT PROPERLY INSTALLED',i have install windows 98 ,it gets installed but i m get6ting this problem with windows 2000 & windows xp
Do you have sata disks? Go to bios and find a option related to sata or raid, and select "compatible mode" or "ide" depending on your bios. Other way is to have your disks drivers ready and when xp ask to install third party drivers you press F6 or the key that xp wil ask to install this drivers during os instalation.
Posted on Sep 10, 2007
SOURCE:
In my hp compaq nx7400 laptop,mic was not detect voice how to identify that what's the problem
most of some notebook computer had only mic capturing, when you talk someone on voicechat, they heard you but you can't hear on your notebook built-i speaker. if you want to check., if your mic is ok...try to record voice....using sound recorder of Windows.
Feb 19, 2011 | HP Compaq nx7400 Notebook
I get no hard disk drive detected when booting or trying to reinstall windows xp service pack. What do I need to do?
how ar you installing the xp with the service pack 2 on it take the hdd out of the computer and check the hdd settings you set it on master if thats not the case then your cable my need replacing
Nov 12, 2010 | Microsoft Windows XP Professional
My HP Compaq NX7400 notebook shows only the hp logo and then the screen goes black/blank. Windows xp boots regularly, I can hear the sound and if I attach the vga cable on the back I can use the computer....
well there isn't much you can do so you will have to get it repaired try to repaire it for a cheap price cause they always rip you off goodluck:) & please rate my solution thanks...
Jun 06, 2010 | HP Compaq nx7400 Notebook
Not recognizing hard disc drive for windows xp reinstall .
Reseat the HDD of the sys.
It will be on the lower panel of the sys
Mar 22, 2010 | HP Compaq Presario C304NR Notebook
Audio driver not installing
Conexant CX20549-12 Audio Driver for Microsoft Windows XP (sp36090.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
This will create a swsetup folder in C drive ("C:\sp36090")
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\sp36090 folder and select the .inf file (CpV30D5a) and click open and Continue with the onscreen instructions
Regards,
Brice
Feb 05, 2010 | Compaq Presario 700 470024-192 Notebook
HDA bus diver required
pls I need the bluetooth drive for my hp compaq nx7300,thank you
Dec 24, 2008 | HP Compaq nx7300 Notebook
I m not able to install win xp sp2 on my compaq notebook
windows xp cant detect ur hdd bcoz its SATA hdd.
Solutions:
1. Install vista instead of XP
2. You need to disable this SATA feature in BIOS to install OS.
SATA disable steps.
1. Restart the computer and start tapping F10 key.
2. Choose System Configuration tab.
3. Disable SATA native support.
4. Save and Exit the BIOS by pressing F10 key
Aug 21, 2008 | HP Compaq Presario V5000Z Notebook
Hard drives not detected
you should repartition your hdd. using disk manager, 1st step. do zero level, then low format. after doing those step. make partition and install your os. good luck
Sep 08, 2007 | Microsoft Windows XP Professional With...
USB DVD ROM no detected
You need XP service pack 2 or later installed on your notebook. Does your notebook detect other USB drvices, if not your USB port on the PC is gone. If the USB prt is working and you have XP service pack 2 installed then you probably got a bum DVD drive so return it and get another.
Jul 14, 2007 | HP Compaq Presario V2000 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
96 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
