Question about Samsung VR8707 VHS VCR
VR8707 VCR. No Rewind or Fast Forward
Deck plays fine but no FF or RW. I'm sure I could fix this if I know how. (parts etc)
  • Burnee Sep 11, 2007
    Thanks for the response. Here's a picture.
  • 1,139 Answers
I thing that you are having problems with your gear assembly on the carriage. FF and RW use a series of gears to move the tape from one reel to the other. If possible could you take some pictures of the gear assembly. More then likely the gears are not making contact or the drive belt has slipped. Granted this is just conjecture until I can see those pictures of the assembly.
Posted on Sep 10, 2007
  • Henry McKelvey
    Henry McKelvey Sep 11, 2007
    OK lets see, what I want you to do is to look at those gears as the tape loads then I want you to hit play and see if the tape spindels move if not you have gear issues or the drive motro is not connecting with the gears.
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
I taped a TV show. But I can't fast forward to see the end part that I want to watch. It just advances to the end.
I'm not surprised that it advances on the end. The VCR doesn't know where the end of the taped programme is. You will have to search manually for it. Start at the end of the tape and rewind a few minutes worth of recording then press 'play' and see what you get. If not successful rewind further and try again, etc,etc. Alternatively you could press "play +rewind" which should allow you to watch the record on what is fast (=x2) rewind. It will help you if you know how long the show was and at what point the tape was when recording started.
Mar 26, 2015 | Televison & Video
VCR needs to be tipped in order to rewind, play, or fast forward.
Sounds like an idler wheel problem on reel table of vcr. Could be loose or maybe spring is stretched or broken.
Aug 29, 2013 | Magnavox ZV420MW8 DVD/VCR
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
JVC VRC MACHINE HR-S7965 Rewind/fastforward cog slip noise
maybe a broken break band on reel supply (left one) in the vcr !!!
Apr 22, 2010 | JVC HR-J461MS VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
Apr 12, 2007 | Denon DRM-740 Single Dual Cassette Deck
Vcr plays ok, but will not rew or ff
either bad mode select switch or bad sensors. my bet would be bad mode switch( pull apart and clean contacts.)
Mar 07, 2007 | Panasonic AG-720 VCR
Televison & Video Logo
155 people viewed this question
Jerry Greenberg
Jerry Greenberg
