Question about Maxtor One-touch III Mini 40 GB USB 2.0 Hard Drive
Maxtor one touch
Is there a way to reformat the file system on a maxtor one touch mini hard drive and chage it to fat 16 or fat 32
    Brigadier General:
  • 6,966 Answers
Hi, You can try and use PowerQuest PartitionMagic. It will allow you to partition/format/check most HDs including USB connected. Choices/options are from FAT16 to NTFS and Linux. Another handy disk utility that is a freeware is HP's bootable flash utility at http://h18000.www1.hp.com/support/files/serveroptions/us/download/23839.html Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Sep 10, 2007
SOURCE:
I have a Maxtor 9NX2DT-500 hard drive for my PC can I copy my File on a Mac Air computer ( is it compatible ?)
Depends on what you want to do with the files. Data is usually interchangeable between Mac and PC file formats. FAT-32 format files are limited to 4gb in size. You cannot boot a Mac from one of these files or from a drive formatted to FAT-32. To be bootable, an Intel Mac system drive must be formatted as a GUID partition map. Most of the new hard drives come with software that enables Macs to read and write to them without reformatting, thus they are completely interchangeable for data.
Nov 25, 2014 | Maxtor Computers & Internet
Maxtor file transfer problems
well..it's possibly the case that the maxtor is looking for mp3 files that are compressed using a different algorithm than what you are sending to it. can you open an mp3 file, and look at the properties, then compare that to your mp3 file specs for your maxtor
Feb 19, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Mator one touch 4 mini 160 gb software, I accident...
Maxtor Manager is not available as a download but you could email Seagate to try to get the files
May 20, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor one-touch mini won't appear on PC
To isolate the problem, please try the steps below:
1. Make sure that the USB ports of your PC are working.
2. Try to connect the device into different USB ports.
3. Try to connect it into different Windows based computer.
Question: Did you reformat this device using your Mac? If yes, there could be a possibility that the device was reformatted using the Mac OSX (Journaled). This type of format would only recognized by Mac computers.
But if it's formatted using the DOS based system, it would work on both Mac and PC.
Apr 01, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
My Mac laptop running OS X 10.5.5 is not recognizing my Maxtor One Touch 4 Mini 320gb external drive. I plug it in, the light on the drive comes on, but nothing else happens.
check to make sure the drive is formatted to the FAT file system as NTFS file system is not recognised on Macs (check the drive on a PC and have the PC format the drive to the FAT file system)
Kind regards and please don't forget to rate us
Dec 12, 2008 | Computers & Internet
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor Onetouch III mini edition
All you should have to do is copy your files from their present folder on your computer to the Maxtor drive; you can find the drive location by clicking on the My Computer icon; or you can drag the files from their present position to the Maxtor.
Maxtor One touch III mini cannot be read on desktop after reformatt
I have seen this one before - you will need to download and reinstall the Maxtor software. If you do not have the CD, you can find it here:
http://support.seagate.com/rightnow/mini_software/otiii_mini.exe
Jan 09, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Open Questions:
See all Maxtor One-touch III Mini 40 GB USB 2.0 Hard Questions
Maxtor One-touch  III Mini 40 GB USB 2.0 Hard Drive Logo
95 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
