Question about Sony PlayStation 2 (PS2) Console
Ps2 dualshock analog controller not vibrating
My ps2 dualshock analog controller is not vibrating but all buttons are functioning. Even I turned the "vibration ON" in the games I used to play such as NBA live?
  • quark2010 Dec 14, 2008
    I have two playstation consoles:
    An old first generation PS2 and a slim PS2.
    The Dualshock(2) controllers from my old PS2 do not vibrate on the slim PS2, but vibrates (very good) on the old and thick first generation PS2.
    The Dualshock(2) controller from the slim PS2 does not vibrate on the slim PS2, and vibrates a little on the old PS2.
    Any thoughts?
    Thank you.
  • 42 Answers
Usually, all dualshock controllers malfunction after a year or so. Do not be surprised.
Posted on Sep 11, 2007
Why is my ps2 saying I have not put in my controller?
some games only except dualshock2s and if it is it says it right next to where the cord comes out of the controller or any version of mad cats should work
Aug 28, 2012 | Sony PlayStation 2 (PS2) Console
Hey!!! I got 2 New PS3 Dualshock 3 controllers that were working perfectly and one day out of nowhere they don't vibrate anymore. I didn't change any settings or do anything for that matter. Please...
Try resetting the vibration on the controllers. press the PS button, Settings, Accessory settings. then controller Vibration functions, Vibration Function ON.
Jan 12, 2011 | Sony Dual Shock 3 Controller for...
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
Dualshock 2 up, down l1, l2 buttons problems
try to open it and press the key that are not functioning,, if it doesnt work maybe its the time for you to buy a ribbon for your joystick,,, you can use your old joystick that are not functioning and substitute them to the one you are using,,,, if you dont have that try asking your friend if they had a ruined controller... mind you that this only works for the original controller not for generic.... generic controller are disposable... once one key is not functioning you cannot expect to work that key again,,,
Oct 19, 2009 | Sony PS2 Dual Shock 2 Controller...
When i touched my dualshock controller, i received a series of electric shocks. when i started up my PS2, the controller's red light was on but the buttons and the analogs won't respond. Then, i tried to...
it sounds like your controller has had what is called an elecro static discharge. the only way to fix it is to replace the controller with a new one as it is fried. there is now way for you to repair it.
hope this helped
please rate well
Mar 06, 2009 | Sony PS2 Dual Shock 2 Controller...
How to check terminals on a dualshock2 ps2 controller
does it stop working?or stopped vibrating?if the vibration stopped then wire connecting to the rotating motor is detached this is the common problem with dual shock because of constant vibration.Solution is to open the controller and connect the loose wire,dust is also a big factor if buttons are already not responding so try also to remove accumulated dust on the button touch board.
Jan 24, 2009 | Sony PS2 Dual Shock 2 Controller...
My dualshock 2 controllers analog are very hard. how to fix it
Hi warren111,
When you say hard, did you mean the controllers analog stick is very "stiff" or loose to the point that you can't move the characters onscreen or the characters move involuntarily. If this is your case then you may have to try another PS2 dualshock 2 analog controller in your PS2, If the problem doesn't happen with another controller, then you may consider buying a new PS2 dualshock 2 analog controller since most likely the controller is already defective.
Also try other games, see if the problem only happens with a particular game. If it does then you will have to check the settings of the game, and see if you can adjust the settings of the buttons or analog stick.
If the problem you're having is more with the "comfort" of the controller you're using then you should consider looking at 3rd party controllers for the PS2. One company that makes them is Logitech, they have a line controllers that work for the PS2 there are other companies so check out gaming sites to get reviews on them. But I would suggest though that if you're shopping for a controller because of this reason, you should try to test the controller out in a game shop first. So that you can get a feel of it before buying. If you like the controller and you're comfortable with it then tha's the time you buy it.
Hope this helps!
Peace! :)
Oct 22, 2008 | Sony PS2 Dual Shock 2 Controller...
Error on Game screen
Jun 30, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
527 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
