Question about Foxconn NF4UK8AA-8EKRS Motherboard
Problems with Ram
I have had numerous problems with my system. I recently installed a new NF4UF8AA mboard with 4 sticks of kingston ram. After a fresh format and install of windows I was still experiencing sluggish performance, very slow install speeds from DVD drive and then hangs and then blue screen crashes. The only hardware connected is a new HD, ATI 1950 pro video card and DVD drive. I tried changing out dvd drives but no fix. I then removed all ram sims except one and suddenly the system started operating with no problems. I rotated individual ram sticks into the system one at a time and tested the performance (very crude benchmark...I timed how long it took to install Company of Heroes). With a single stick of RAM, the system was very responsive and installed COH in 5 minutes. After testing the ram individually and determining that it worked well alone, I then added a second stick (same brand and speed) into DIM1 (1st stick in DIM0) and rebooted. The system became sluggish again. I had already removed COH, tried to re-install with both sticks of ram. Crunched on the install for over 5 minutes with less than 10% completion. I repeated this entire process with a total of 4 sticks of RAM (2 pairs of matching brand and type). I am at a loss now...any help would be greatly appreciated!
    Novelist:
  • 231 Answers
Hi, with my own Foxconn board I had simalar problems, the Foxconn website gave me the needed steps to rest the bios to cope with 4g RAM. I have forgotten the steps now. The web page is the one on the install disk, if you go to Foxconn via google you will only get a company promo. Regards mistyman
Posted on Sep 10, 2007
SOURCE:
Driver memory stick
Try putting the ram in another computer and see if you have the same problem. If the issue goes away one of the sticks of ram might not have been fully seated. If you get the same result you have a bad stick of ram. Go to the manufactures website and download ram checker and install it (free software). This will help diagnose your problem. If you get an error code write it down so you can give it to the manufacturer which indicates which error problem you have... If it turns out that you have a bad stick of ram contact the manufacturer and they may send you another stick of ram. Some manufacturers have a lifetime warranty on their ram. Hope this helps.
May 11, 2017 | Kingston 4GB Secure Digital High Capacity...
Hi, what RAM can I or can't I add on my GA-8I945PM ?
No, *********** board only supports DDR2 Ram thus the PC2 in your current RAM. Also the maximum capacity of your motherboard is 4gb. So if I were you I would recommend going to 4 1gb PC2-4200 modules. This would reduce latency as opposed to 2 2gb sticks. Also I recommend the 4200 rather than the 6400 or anything else as that is the optimal speed for your motherboard. Kingston is a good company to buy from, I am currently using 8 Kingston FB 2gb DDR3 sticks in my MAC Pro.
Mar 29, 2012 | Computers & Internet
I recently purchased 2 1gb pny ram ram sticks hoping to upgrade my ram. After installing the 2 sticks the computer doesnt boot. I reinstalled the original 2 512mb sticks and the computer works fine. Is my...
Without the computer model and make I can't say if it is upgradable or not. Most are upgradable to some extent. You will need to look for the product description of your laptop on the manufacturer website you may want to download the user manual from them or check the manual you have if you still have it. Yo9u are looking for the max ability of the computer and at the speed and type requirements for your ram. Also, you should know that some companies make Ram of the correct type and class but for some reason will not work in some models. I have Kingston ram 2gb modules that will not work in my Laptop but I purchased Siemens Ram of the same type and it works fine. So it may just be a matter of Ram Manufacturer.
Jan 14, 2011 | Computers & Internet
HP Compaq dx2200 doesn't detect RAM
Go here and supply the info for your system or mboard model to determine which G.Skil module part numbers are listed as compatible with your system or mboard:
http://www.gskill.com/configurator.php
If your system model or mboard model is not listed, or if it is listed but they don't list the module part number(s) you have, there is no way of knowing whether the ram will work properly in your mboard !!.
A common thing that can happen with ram, even ram that worked fine previously, is the ram has, or has developed, a poor connection in it's slot(s).
This usually happens a long time after the ram was installed, but it can happen with new ram, or after moving the computer case from one place to another, and I've had even new modules that needed to have their contacts cleaned.
See response 2 in this - try cleaning the contacts on the ram modules, and making sure the modules are properly seated:
http://www.computing.net/hardware/w...
If your ram passes a ram test, it's working fine, even if you can't determine whether it's listed for your mboard or system model anywhere
If you do a ram test, do that AFTER having tried cleaning the contacts and making sure the ram is seated properly - otherwise any errors found may be FALSE.
If the ram is incompatible with the chipset, or on more recent computers, incompatible with the memory controller built into the cpu, it will likely FAIL a ram test - that is NOT a true indication of the ram being faulty - there is probably nothing wrong with it, and it will pass the test if installed in a mboard it is compatible with.
NOTE: Sometimes incompatible modules (or matched pairs) won't work properly when more than one is installed, but will pass when by itself.
If you want to try a memory diagnostic utility that takes a lot less time to run a full pass than memtest86 does, this one is pretty good - Microsoft's
Windows Memory Diagnostic:
http://oca.microsoft.com/en/windiag...
It can be toggled (press T) to do a standard or a more comprehensive set of tests - use the default 6 test one first - if it passes one pass of that, use the latter one. A few of the tests in the latter set are intentionally slower.
If you don't have a floppy drive, see the Quick Start Information at that Microsoft link for how to make a bootable CD of the Windows Memory Diagnostic (you need Windiag.iso - you don't necessarily need to use the program they mention to add it to the CD).
If the part numbers of the ram modules you have ARE listed for you model, and/or in any case. if you STILL get ram errors.....
Some ram manufacturer's modules do not strictly adhere to the JEDEC standards that most mboards bioses use to determine ram settings.
In that case, the ram settings in the bios Setup that the bios has automatically chosen may not be correct.
Check the ram settings in your bios - the ram voltage, and the ram timing numbers - those should be the same as for the specs for the modules themselves. Often the ram voltage and timing numbers are printed on the label on the modules.
If the voltage setting or timings settings in the bios are different from the specs for the ram, change them in the bios. The timing numbers must be as close as you can get to the same, or slower timings (higher numbers = slower) - you won't notice the difference the slower settings make.
If you have a mix of different modules
- don't mix ram that different voltages arespecified for - the bios will force the ram to use the lowest voltage, if "by spd" or similar is used (default settings) - ram that a higher voltage is specified for is more likely to not work properly in that situation.
- the bios settings must be those for the slowest timing settings of all the modules, or slower (higher numbers = slower).
G.Skil is one of the "also ran" ram module manufacturers.
According to The Muskin web site, some "also ran" ram module manufacturers test their ram modules when they're by themselves in a mboard, to get the best (fastest) timing ratings. When you install more than one of their modules, the timing may not work properly with more than one module installed, but if you change the timings in the bios Setup so that the timings are slower (higher numbers) , the ram will work fine.
I have seen several examples of people who posted on this site having to do that with G.Skil ram.
May 27, 2010 | HP Compaq dx2200 PC Desktop
I have got a compaq presario 6000 series pentium 4 desktop. I bought a 1GB kingston PC2100 DDR ram, 266Mhz ram for upgrade from my earlier 256MB ram. Somehow my desktop doesn't detect the memory upgrade...
the bios might be seeing it but windows might not, the possibility exists that windows is not able to view the full amount of ram installed try this. go to the start menu > accessories > system tools option and look for the system information tool, this will tell you more about the ram installed, note: windows dose on occasion report the wrong amount of ram when their is a 64 bit os installed or their is a 64 bit system
Dec 14, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
I have a abit v17 mobo want to get max ram (2gb) bought kingston value ram from kingston rep said it would work. also have corsair matched memory also was told by rep that it would work. I plug them in and...
Your motherboard supports DDR SDRam I assume the ram sticks you bought fit in the socket correctly and are the right way round?
Try the computer with each ram stick seperately. Just because ram is new doesnt mean its not defective.
What configurations do you have?
Are you using two corsair sticks or two kingston or a mix of both and what models are they?
Jun 19, 2009 | Computers & Internet
Windows XP Professional x64 Will not start up with more than 2gb.
Move your ram into different slots, put different ram in slot 2 or 3, sounds like bad ram, 32 bit apps access ram VERY diferently that 64 bit apps.
Mar 25, 2009 | Microsoft Windows XP Professional x64...
2 GB or more RAM is not functional
try maybe theres a problem in memory compatibility...dude first try to put same memory card brand and specs
Sep 01, 2008 | MSI K8N Neo4-F Motherboard
Installing new ram...wont work
Go HERE for troubleshooting guide. Scroll down to: Stability Problems - Memory Issues.
Jun 03, 2008 | MSI 915P Neo2 Platinum Motherboard
2 x 2GB Kingston CL5 detected as 1 GB each one
Ok, I got it, Ur motherboard supports upto 8GB DDRII Dual channel
Try using these RAMs on other slots of the board to check if there is a problem with RAM Slot (As there are four slots on ur board).
If no success, try using RAMs on some other system to confirm whether problem is with RAM or Motherboard.
Mar 15, 2008 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Foxconn NF4UK8AA-8EKRS Motherboard Logo
89 people viewed this question
Top Foxconn Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
