Question about RCA 24V511T 24" TV
35GT740 television
It keeps scrolling through the channels, I cannot make it lock on any one channel, it is like being stuck in a search or scan mode.
  • 3 more comments
  • msgarrett95 Sep 24, 2007
    Nope, i have checked all the buttons, even took apart the remote, cleaned ity for any sticky buttons, no luck, any other ideas?
    nope, nothing spilled, sprayed, or whiped, no children. Any other ideas?
    I honestly do not understand your reply. I cannot lock it on ANY channel, it just keeps scrolling.
    Yhat is what i am thinking, where do I get a new TACT switch.
  • msgarrett95 Sep 30, 2007
    I removed the back of the TV and removed the printed wiring board that is on the backside of the buttons on the front of the TV. I pressed all of the switches on the PWB, they all seemed to be functioning. I reconnected the TV and powered it up, and with the PWB in hand, (it has an extra long connector cable) I checked the channels. It worked. No replacing switches, PWB's or any soldering. The malfunctioning switch must have just been stuck. I reassembled the whole thing and it works fine (don't forget to ground yourself when you are touching the electrical components).
  • 790 Answers
Replace a new tact switches! do not clean the tact switches with spray solution! or even you open the tact switches maybe its works!but the best change all tact switches!
Posted on Sep 24, 2007
  • 398 Answers
Most likely there is some kind of contamination on the channel up or down pushbutton. The pushbutton is the actual little switch right behind the button on the front of the TV. If something is sprayed on the screen, such as spray cleaner or a child's drink, it could seep down and contaminate the pushbuttons and board. This could cause leakage inside the pushbutton, and the computer reads this as someone pushing that particular button and responds accordingly. The board can be cleaned and the contaminated pushbuttons replaced, but that should be done by a qualified tech.
Posted on Sep 11, 2007
    New Friend:
  • 76 Answers
Keep the channel in any one of the program no. say for example channel no. is 5. Keep the channel as it is, now check the program is scrolling but the channel no. will not change in to 6,7,8,9.... like that. Suppose there is a change in program means AFT section is not working properly. Apart from number also changing means, in menu options check any child lock or keypad lock features. Anyone is present locked the system and then give feedback symptoms.
Posted on Sep 10, 2007
    President:
  • 3,130 Answers
Have you tried to unplug the TV set for a half hour or so? If not see if that helps reset the set. If that does not work, make sure that none of the front panel channels buttons on the front of the TV set is not pushed in and stuck. Or if all this is checked and the TV set still scrolls, there is a problem in the remote sensor, or the front panel board will need to be replaced. Good Luck
  • Larry  Dillon
    Larry Dillon Sep 24, 2007
    Common problem, replace rgw front control board, or if this model does not have a front control board, replace the small switch behind the channel up and down buttons first. This will involve soldering. If you have no soldering experience, please play it safe and take the set into a repair shop. Good Luck
SOURCE:
How do you program channels over the air
Hi, on your remote press menu, scroll to "tuner" then select "air", then below should be "auto scan" scroll to it you have an option to stop< and start> press > (or just enter to start your scan for new channels. If you get stuck, hit the menu button again and begin again. Have a great day.
Sep 28, 2014 | TruTech Televison & Video
My samsung tv channels keep scrolling from 135
Hi Jorge
Check on the remote if the buttons aren't stuck / sticking then check on the side panel of the television if the button there are not pressing against anything.
Lastly check to see your channel setup is fine and do a auto scan for the channels to ensure that it's not a memory issue
Sep 28, 2014 | Samsung LN40A500 LCD TV
Tv stuck one channel
Be sure tv is set to antenna and not cable . Do auto scan . Find this in setup menu. If this does not work check the mfc website for software update. replace the main board as last resort.
May 29, 2013 | NEC Televison & Video
How to tune a TV Manually
Select Menu and scroll manual search. the press to tune as the search starts. Now for every scanned channel that locks you might hav eto assign the preset location number, then proceed to search once again. You can manually select and set according to your wish.
Sep 15, 2010 | Televison & Video
Tv keep scrolling backward through channels
I think that your channel down button is stuck in..If you dont hear and feel it click compared with the channel up button then it has
Aug 06, 2009 | Daewoo Televison & Video
Channel Search
With remote, hit MENU, (use up/down arrows) & scroll to SETUP. Hit ENTER & scroll to TV. Hit ENTER & scroll to AUTO CHANNEL SEARCH. Hit ENTER & scroll to CABLE. Hit ENTER & scroll to AUTO. Hit ENTER, wait as it scans (about 5 min). Your done.
Jun 18, 2009 | Televison & Video
Cannot set channels
It is the software or the program that have the TV to operate properly.  Sorry for my english.
Dec 19, 2008 | Acer AL2671W 26 in. LCD Television
Rca F32649 32"
I had the same problem and eventually found the solution. the tact switches behind the front panel buttons will leak when they get old causing them to activate on their own. your channel up or down button is stuck on. take off the back cover and you will see a small clip in circuit board behind the front panel. take out the board and remove the channel up or down switch and your set should work fine again. the remote will still work fine for changing the channels.
Aug 14, 2008 | RCA F32649 32" TV
Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Jul 28, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Scrolling
Sounds like it has one of two problems first one could be a stuck button. The micro locks up and the set wont come on also could be causing the channel scrolling run you finger along the channel buttons. Other than that you would need a new signal board you have a locked up micro...this part will be No longer Available.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
RCA 24V511T 24" TV Logo
277 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
