Question about Sony XM-2002GTR Car Audio Amplifier
Protection light i have my sony xm-2002gtr hooked up to 2 rockford hx2 1000 watt subwoofers and the subs are hooked up in parralel and bridged to the amp with 5 guage 1400 watt wiring but my protection light indicator comes on when i turn up the bass and shuts my amp off. how should i adjust my controls on my amp?
  • 123bigson Sep 11, 2007
    i had know idea! i thought the amp was 2 ohm stable at bridged but read more into it and its not thanks you saved my amp and subs!!!!
    ok! now how would i set my controls for nice low bass
Thanks sounds just as good, doesnt cut out any more, and my sound system will live longer!!
Posted on Sep 15, 2007
  • 752 Answers
You cannot parallel two subs AND run them on the Bridge. You must have at LEAST a 4 ohm load on the bridge, and 2 4 ohm subs in parallel equals TWO OHMS. BAD!!! Move each sub to it's own channel or your amp will soon fry.
Posted on Sep 10, 2007
SOURCE:
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
Xm-2002gtr amp keeps kicking protect light on
check your amp and speakers and make sure their both hooked up 4 ohm instead of 2 ohm because if you have 1 set of voice coils on your speakers they can only be hooked up four ohm and not bridged to your amp because if you keep trying this you will lock up your speakers if the speakers are only 4 ohm than just hook them up regular to each channel on your amp if your trying to brigde four ohm speakers to your amp it will keep going into protect or worst case scenario you will fry your speakers and you can check your ohm with a ohmmeter trust me my brother owns a stereo shop
Oct 19, 2009 | Sony Car Audio & Video
Amp goes into protect when turned up.
that amp is only stable 2 about 4 omhs mono the powersupply shut dowm drawing t much current it supposed 2 2 fix this u need a 4omh load mono change speaker config so u get 4 omh or buy amp stable down 2 1omh can be expensive
Aug 28, 2009 | Sony XM-2002GTR Car Audio Amplifier
I have 2 1100watt sony xplods will they run off a 1000 watt amp
yes it will work, but it will only put out the power to the sub that the amp allows, ie : 100 watt amp puts out 100 wats.
you can also try reconfigering your wire to your subs, if your amp is 1ohm stable and your subs you can come off the amp with a bridge and run subs in series or parralell, this will dramaticly improve the bass
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Amp shuts off when music turned up
try adding a capacitor to feed the amp. these are large in capacity (farads)and dims (about 6' x3' dia.)...what wire size are you using?
May 30, 2007 | Sony XM-2002GTR Car Audio Amplifier
Protection mode override
If you have your subs wired to the amp in a bridged configuration, try wiring one to each stereo channel instead. Also, make sure your ground wire is secure and connected to a clean, solid metal part of the vehicle body with the paint scraped off. If this doesn't work, disconnect both subs and try connecting only one at a time; one of the subs may have a problem that is shutting down the amplifier.
Mar 11, 2007 | Sony XM-2002GTR Car Audio Amplifier
Sony XM-2002GTR Car Audio Amplifier Logo
288 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
