Question about Compaq CV 7500 17" CRT Monitor
Monitor no Desplay
I have this problem that my monitor will no longer displaying, I tried my best solution to resolved this problem but I always be failed, I removed the memory, I checked the video card, but the problem is always the same, I restart my computer but it?s the same result, It is possible that my IDE cable is the problem? Can you help to fix my problem? Thank you and more power!!!!!!
Reset the bios jumper settings,jumper it to 2 and 3 terminal, or do the erasing of memory card.
Posted on Dec 07, 2007
  • Anonymous Dec 07, 2007
    reset the bios jumper settings, jumper it to 2 and 3 terminal after 3 minutes back to its original jumper settings, or remove the memory and memory connector ny erasing it with an eraser.
SOURCE:
Cannot get the picture wide
Firstly you have not mentionrd thr Make & Model of your monitor.
Assuming it's a LCD Monitor you could try the following:
Modern monitors have a 'native resolution'. While most LCD monitors can display a wide variety of screen resolutions, the native resolution will always look best, since this is the screen resolution that matches the number of pixels inside the display. Any other screen resolution may look blocky or distorted, since the number of pixels used in the picture will not match the actual number in the display.
You can adjust your computers display resolution easily. For best results with your monitor, you should use the latest display drivers and monitor drivers and run your monitor in its native resolution. For more information on updating your display drivers, see this link.
Also have a look at this video
May 20, 2012 | Computers & Internet
Hello sir my samsung lcd monitor model no 740N . in dis monitor right side display two verticle lines green n light pink but hoe to i resolved dis problem please give me suggestion
You cant resolve it tiny resistors in the screen have failed and that is why the lines have appeared, it is a case of live with it or buy a new monitor
Feb 24, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
I have Dell 1907fpc monitor. The image flickers and finally darkens. how to resolve the problem?
It sounds like your LCD Backlight/s are going out. To fix you will need to replace the LCD screen inside the Monitor. It may be more feasible to replace the Monitor.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 24, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
Hi! The Belinea 1705 S1 monitor screen turns off after about 15 seconds. If I turn off and on, again it happens. I tried to enter the menu, but the OSD-LOCK displayed. What's the problem and the...
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"....if the problem continues. Switch of the monitor and remove the power cable and connect it again.
hope this helps and good luck with the problem and by the way don't forget to vote for this solution.
Nov 11, 2010 | Maxdata Belinea 1705 S1 17 inch LCD...
Long warm up time
It is most likely a monitor problem, unless your video card/ or computer is failing to boot in a timely manner. The only thing that would effect the monitor taking a while to turn on is if there is no output to be displayed. Easiest way to check is just connect another monitor if available. if yo have a non integrated video card, make sure its properly connected.
Apr 07, 2009 | BenQ FP767 17" LCD Monitor
Fuzzy screen, not a flat screen.
TFT Monitor fuzzy display problems are almost always caused by one (or more) or the following issues:
  • Wrong display resolution. As mentioned elsewhere, TFT Monitors must be configured to use their Native Resolution in the PCs display settings. Failing to do this will always cause the display to be fuzzy or blurred - or to have jagged edges on diagonal lines and a 'lumpy' looking display.
  • Poor adjustment. If the display resolution is correct, then the monitor has to be correctly adjusted to get the best picture quality. This is usually only an issue with analogue monitors. If the digital (DVI) input is used, then further adjustment of the monitor should not be required. Initially, the monitors "Auto-Adjustment" can be used to try and improve the display quality. This is best used with a program producing a test pattern of vertical lines, with a single pixel white border showing the exact edge of the screen. Given this, most monitors will auto-adjust perfectly well. If the display is still not perfect, a very slight manual adjustment will usually achieve the expected quality.
  • Poor quality cables. Monitors are susceptible to signal degradation from either poor quality or excessively long signal cables. Also, joining or extending cables is likely to cause ghosting effects on the display, usually seen as light and dark vertical lines.
  • Faulty graphics cards or other component. In most cases upgrading the driver ill resolve this issue. If none of the above suggestions work then get me the brand and model number of your graphicscard and we will update the driver.
Nov 16, 2008 | Kogi L9CH 19" Flat Panel LCD Monitor
My computer doesnt boot
Hi Ashish
There is no problem with ur system board.
Actually you are getting this problem because of Monitor problem.
The possible cause would be:
1. Your data cable connecting your board failed.
2. The display IC of your monitor failed.
3. If you have Video card then remove video card and try connecting data cable to monitor port other than ur video card.
most probably u are dealing this problem due to failure of ur display IC.
Troubleshoot first by connecting other monitor with ur system if available.
gimme ur acknowledge by rating me
Thanx
Romy
Aug 05, 2008 | Computers & Internet
Compaq CV 7500 17" CRT Monitor Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
