Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp ar 5316
The paper copies is blank help me please
  • Anonymous Jan 15, 2008
    I DON'T HAVE DRIVER FOR THIS DIVICE
Haregaa Fecoom
Posted on Oct 27, 2008
  • 163 Answers
My dear sir pleaz open the right cover and check the transfer corona wire if transfer corona is broken then replace it only.thanks or there is moisture in ur papers dry before use
Posted on Sep 12, 2007
2 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Sharp ar-5316 E Problem
Make sure that the side door is secured. There is a corona wire in a brakced on the door and if it does touch the rest of the machine correctly, blank pages will spit out.
Posted on Aug 02, 2008
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
I JUST BOUGHT A SHARP AR-5127 COPIER..WHEN IT COPIES, IT BRINGS OUT BLANK PAPER. I REMOVED THE CATRIDGE AND IF I TURN IT UPSIDE DOWN,SOME BLACK DUST COMES OUT...PLEASE SOMEONE HELP ME
Hi iheanyippaul,
I see you concern, I believe you will need to check your toner if it is placed properly inside the machine seems that it is not locked/latched in its place to be able to print properly reason why you get a blank paper and black dust when printing.
Remove the Toner and re insert it again making sure the toner is set properly inside and also make sure the correct toner cartridge is installed, an incorrect or incompatible toner can cause issue of not getting to print anything on the paper or possibly not fit inside the machine correctly.
I hope this helps.
Have a nice day,
mvincentc
Jul 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
We are trying to connect the Desk top PC so as to use AR=5316 as a printer.Need help to install the printer software. Can I get it downloaded from Sharp site. Please reply.
you may gey the driver software for AR=5316 printer install sotware inthese websites
http://nodevice.in/driver/AR-5316/get47086.html
http://ptf.com/sharp/sharp+ar+5316+printer+drivers+to+support+windos+7/
Apr 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp 5316 1 copy good 2 copy good 3, copy blank copy machine on off repeat 3, copy balnak what is the problem
problem on high voltage unite or corona assemble
1.Clean & wash high voltage thoroughly.
2.Replace corona ware,and assemble new corona
upper and lawyer charger.
Jan 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Jan 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
How do I instal my printer to my P.c.
YOU CAN DOWNLOAD THE DRIVER FOR YOUR SHARP COPIER ON ANY SHARP SITE.
Jan 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5132 blank copy
see comments, loose blade by roller, push in, fixed
Dec 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
Aug 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
AR 5316 VERY DARK BLACK COPIES
You need to check the drum unit for wear or the main charge assembly. If you are not mechanically inclined, just replace the drum unit and clean the transfer charge on the right side door.
Don't forget to rate your answers please.
Jan 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
95 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
