Make sure that your chain isn't adjusted too tightly, and that you've adjusted the force settings on your opener. There is also a little black plastic wheel with slots on it that must be aligned with a small control board with a black plastic U-shaped piece. If everything I've described is correct, then you should call a door serviceman to inspect the opener.
SOURCE: garage door opener does not reverse after hitting obstruction
release the door from the opener and see if door moves freely the check proper torsion by moving door up to 3-4 ft if it stays in this area torsion is properly set if not call technician to adjust torsion
if door does not move freely all the way up and down check for binding track alighnment and roller condition. the adjust closing pressure.
SOURCE: Liftmaster 1/3 HP opener won't close
strange, was going to say eyes not aligned but you say they are. try over-riding by holding down wall pushbutton or jumping from red and white terminals. Did you increase down force. Are limit switch terminals moving, If it hits one, it should go back to other,
SOURCE: My Liftmaster GDO makes a clicking sound and won't open
See if the trolley is jammed against the bolt just in front of the motor unit. If so remove the bolt and then run the opener until the door is closed. While the door is closed locate the 'up limit' control which is on the side of the motor unit. Turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Remember to replace the bolt.
SOURCE: Liftmaster 1265 won't motor more than a foot in the down
Check, The black interruptor cup. See if it has powder from gear on it , Remove particles, And run a Q-Tip between the two little towers on the RPM sensor, Which the interruptor cup rotates into to count rpm cycles.
