Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Trouble connecting downdraft fan
I bought second hand a jenn air sve47100 and I am trying to connect the wire for the fan, however I do not see where I need to plug it into? Can you help? I do not have a installation manual, just a user guide I got from here. Thanks
  • Anonymous Nov 06, 2007
    My model is s160-c. Can I have the installation manual ?
    Thank you
    Chantal
    [email protected]
  • karmine Dec 23, 2007
    having problem mounting downdraft fan to sve 47600 have electrical hookups just dont know where to place the blower on the underside of stove. do you have installation guide?
Don't have an installation manual anymore either. What I remember from ours (and from what I can see from the front) is that the fan connects near where the main power cord attaches to the range itself. Probably not much help, but if I can find the install manual, I'll try to provide more specifics.
Posted on Sep 11, 2007
Www.shared.whirlpoolcorp.com has the manuals online.
Posted on May 25, 2008
SOURCE:
F1 fault code? Jenn-Air SVE47100
HI. This is concerning the relay board that is installed in your unit. I would recommend to inspect the entire wiring harness that is linking the relay board to the elements, and other power component's. If the harness is ok, and connected tightly, and correctly, this will confirm that the relay board has failed. It must be replaced in the case. Be sure to inspect all wiring harness connections for corrosion before you replace the board. This could be as simple as a failed connection.
PRB Part Number is #71002144
Nov 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
F3 error code
Check the connection from the temp censor to the board. A break in the wire will cause the F3 and fan to run. Good luck.
Apr 11, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I have a Jenn Aire SVE47100 that keeps beeping
my stove did the same thing. I turned on the downdraft fan and it quit. I think it overheats the board when you are baking. try it and see if this helps.
Jan 02, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air downdraft blower doesn't work
thiknin thats a sealed unit, however imn sure they got it into a housing so i guess if you lloked close enough ther ewpuild be a few screws to gain access to the fan itself and with it open a quailty degreaser should work wonders in cleaning it!
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
JED8430 Fan Burning
great love it when people do this just commom sense most of the time
Dec 28, 2007 | Jenn-Air JED8430 Electric Cooktop
I just got this Jenn Air...bought it 2nd hand in a store..how old is it?
Have a look through this lot, there are a few problems for your model discussed, but nothing that sounds like a known problem for the model; http://www.applianceblog.com/mainforums/archive/index.php/f-64.html This link has a good description of a common problem with the model (temperature too low compared to the digital readout) and it's solution; http://applianceguru.com/forum1/955.html this link has a good collection of reviews on the stove - people were still buying them new in '98, couldn't find exactly when they started selling them; http://www.epinions.com/hmgd-Ranges-Jenn-Electric-Jenn-Air_Slide-In_30-Inch_Electric_Range_SVE47100/display_~reviews If you have any problems and need parts, there are still many companies offering them online for this model - just type "jenn air SVE47100 parts" into google and you will get a good selection. Sorry I had no luck finding a user manual online, free or otherwise, you could try contacting jenn air direct to see if they could send you one; http://www.jennair.com/content.jsp?name=contact_us Hope this helps :)
Jul 06, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
292 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
