Question about Philips HDD1630 MP3 Player
Pictures wont show.
I followed one of the solutions on another thread...but it didn't work. my problem is that...i can put in the pictures,but then when i try to look at the pictures...it says"list empty",PLEASE!!!!!!!! HELP ME!
  • oxie Feb 16, 2008
    THANKS!!!!!!!
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
SOURCE:
Top thread from spool somehow gets out of the needle when sewing. Sometimes top thread breaks; other times it just escapes the needle. I redid threading from top and from bobbin to see if that would fix....
Try loosening the tension and pulling a longer string of thread. Also, if the needle is not at the highest point, when you start sewing, the thread will pull out.
May 27, 2011 | Brother LX3125 Sewing Machine
I need help on removing a broken bleeder valve on the rear drum of a 1993 Chevy full size truck. I have tried EZ out and didn't work.
BUY NEW BRAKE WHEEL CYLINDER IF BLEEDER VALVE BROKEN. BRAKE WHEEL CYLINDERS DONT COST THAT MUCH.
May 20, 2011 | 1993 Chevrolet K1500
I installed a new hard drive in my PC. It installed itself after I turned on the computer but it doesn't seem to show up on My Computer as a individual drive. BIOS and the Sys Info recognizes there is a...
Are you sure your BIOS is not showing the old hard-drive you had before you installed the new one?
On the new hard-drive you bought, do the following step
there should be a jumper that came with it, put the jumper to "master",
if that didn't work, put it to "slave", if that didn't show up, put it to "cable select" and try it.
If all failed, totally remove the jumper and try.
Also check in the BIOS to make sure that the Drive is not disabled.
This seems to be a problem from the jumper.
Please rate 4 stars if this helped you.
Apr 26, 2011 | Seagate HDD 1TB 7200RPM SATA600 32MB 3YR...
How to get the shaft out of evinrude 1988-89 v4 outboard
We had some success suspending powerhead (if removed from lower) and first rattling the shaft with an air chisel (using blunt head) - worked best on dry rust. If that didn't work it was soaked for a few days in rust buster. and tried again. If that didn't work, we put a bearing splitter on the groove above the pinion splines and a perfectly cut threaded pipe with a threaded union on one end over the drive shaft in such a manner the pipe would apply pressure to the crank shaft when the union was unscrewed.
Now if that didn't work, you can cut the drive shaft off the engine at the crand shaft and drill a hole thru the stuck part. Then tap a thread into the hole and thread a bolt into the stuck part till it bottomed out in the crank shaft and continue to thread it in and it would walk the piece out -saving the crankshaft.
Hope it doesn't have to go that far.
Dec 19, 2010 | Clymer EvinrudeJohnson Outboard Shop...
Please tell me exactly how to thread the bobbin on a 3620. I have followed the instructions, but I don't have a picture showing the bobbin when finished. I start with the bobbin thread coming from left...
I also own 2 necchi sewing machines, I used to have a 3620 myself,,
in my operation manual it has a picture of threading the bobbin case,, if you would like a picture send me a comment with your email address
Nov 17, 2010 | Necchi 3620 Quilter Mechanical Sewing...
On a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Jul 05, 2009 | Baby Lock Ellure
The threads are stripped on my Hayward sand filter drain plug.
I've had the same problem every year since I bought this house 10 years ago with my Hayward filter drain and finally MacGyvered a great solution. Went to Home Depot and bought a 1" PVC shutoff valve. The Hayward drain has an outside 1 1/4" thread. The part I got was an 'Aqua-Dynamic' 1" PVC Schedule 40(I can't find a picture of it on the internet). It is a white PVC valve with an inside thread that mates with the Hayward and a red shutoff winged knob. You need to hacksaw the red wings off the knob in order to be able to screw it onto the drain because the filter's base gets in the way. Leave the valve in the open position(especially if water is still draining with filter off) and put PVC cement on the outside of the drain thhreads and a bit on the inside of the valve and screw it on. When the glue dries(5 minutes), you now have a drain that you can open and close every year with ease(you need a pair of pliers because the wings are off the turn knob but it works great!)
Jun 10, 2009 | Hayward SAND FILTER, PRO SERIES
Ipod wont work
If you have already tried to reset it and nothing happens, try going on this link below and follow some the solutions.
http://discussions.apple.com/thread.jspa?messageID=6953032&tstart=0
I hope this helps
Dec 01, 2008 | Apple iPod nano 3rd Generation
Huskylock 910
I received a cd with my machine showing step by step how to thread it. I put the machine beside my computer and threaded it step by step by watching the cd. One problem I had after threading it was not being able to sew a chain without the thread matting up and making a real "mess". The problem was I did not push the thread up against the machine until it clicked. That sets the tension. Try that and if you still have a problem email me and I will try to help. [email protected]
May 20, 2008 | Husqvarna Huskylock Computerized 910
Philips HDD1630 MP3 Player Logo
35 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
