Question about Nokia 6600
Nokia 6600 joystick (to the left) not working
Hi, I have a nokia 6600. The joystick is fine when pointed up, down, and right. But then when I direct it to the left, it isn't working. How can I fix this problem? It is a hassle since there are times like when I want to change the volume settings and I can't lower it since it does not respond when I push the joystick to the left.
  • fantas Dec 15, 2007
    my joystick wont work at all..what should i do?
  • aayazz Jul 18, 2008
  • 3 Answers
I HAD THE SAME PROBLEM WITH MY NOKIA 6620 FOR 3 DAYS. AND I OPEN THE PHONE AND PLAY WITH THE JOYSTICK AND IT STARTED WORKING. TRY THAT...
Posted on Sep 13, 2007
    Sergeant:
  • 452 Answers
Remove joy stick rotate it by 90 degree & insert it again.there r 4 points beneath it for 4 directions ,it is not sensing the left one .otherwise u can replace the joystick from nokia care centre.
Posted on Oct 10, 2007
SOURCE:
Joystick
Hello, welcome to Fixya!
Do you mean your phone is having a joystick problem? If yes, disassemble the phone, free the joystick with your hands by using your finger to navigate it up-down-left right severally.
Assemble the phone and check the joystick. If problem persist, take the phone to a repairman.
Good luck.
Nov 28, 2011 | Nokia 6600
Most of the time my the left button joystick remain unactive
ur set must be old. actually ur joystick needs a cleaning. it might be due to lot of dust.. but there r more chances tht u will have to get ur joystick replaced. it is a common problem in nokia 6600. mine 6600 down joystick was inactive and when it was active it moved thre 4 times all together. so i got it replaced.. pls rate
Aug 12, 2009 | Nokia 6600
How to change nokia 6600 joystick
ok it will be fine take your phone to nokia priority there you can get your joy stick change
Nov 12, 2008 | Nokia 6600
Joystick
It is rather frequent problem with Nokia.
If your mobile warranty is expired then try to disassemble your phone and clear you joystick of dirt.
If it doesn't help then nothing can be done but bringing it to service.
As far as I remember menus on 6600 are not recurring so you can not use only up direction to reach icons that are below. I did so on E70 when had he same problem with joystick.
Jun 29, 2008 | Nokia 6600
Nokia 6600 joystick
make a jumper w/ a jumper wire joystick #4 to flex #4
skilled technician can performed the jumper'
or replace it w/ new keypad joystick of 66..00
Oct 21, 2007 | Nokia 6600
Joystick problem
see budy what u cud do is open up the cover of ur handset blow some air into the part of joystick might have some dust particale stucked there, otherwise change ur joystick.
Oct 20, 2007 | Nokia 6600
Cant go left with the joystick more in msg
remove joy stick rotate it by 90 degree & insert it again.there r 4 points beneath it for 4 directions ,it is not sensing the left one .otherwise u can replace the joystick from nokia care centre.
Oct 09, 2007 | Nokia 6600
Nokia 6600 joy stick problem
Open the phone..remove the joy stick & rotate it by 90 degree & insert it again.there r 4 points beneath it for 4 directions ,it is not sensing either one of them.otherwise u can replace the joystick from nokia care centre.
Oct 03, 2007 | Nokia 6600
Joy stick
you need to clean the joystick. Sometimes just a pressured air can can solve it.
Sep 24, 2007 | Nokia 6600
Joystick porblem
when u getting that problem just switched off and restart it work autometically...or else open the front cover and clean it.
Jul 30, 2007 | Nokia 6600
Nokia 6600 Logo
872 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
