Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
SD Mini card
How can i format the Mini sd card in my Razor K1, Thanks. julian
  • 72 Answers
Settings>phone status>Storage Devices>Memory Card> Options>format
Posted on Oct 18, 2007
  • michael masterson Nov 16, 2007
    Do you not have those options on your phone? that's the proper proceedure.
    Problem Solver:
  • 30 Answers
The best way is to do it through your computer
Posted on Sep 11, 2007
2 Suggested Answers
  • 35 Answers
SOURCE: SD Mini card
Well those old poes have maximum memory support only till 512 mb so try inserting it
Posted on Nov 26, 2007
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
  1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
  2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
  3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
  4. Right-click on the drive and select the "Format" option. A menu window will open.
  5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
  6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
WARNING
  • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
  • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
Sep 25, 2009 | Electronics - Others
How do I format the mini sd card for my at&T LG Xenon Gx500
You can format your sd card through card reader to attach the computer by format command or you can also format the card through format command in dos.
C:\> format :drive name
Sep 23, 2009 | LG Xenon GR500 Cell Phone
Unreadable memory card!!!!motorola krzr k1
you may have to buy a memory card reader, plug it into your computer and format the memory card before it will work in your phone, or your phone may require a different format of the same card, for instance some camera's take SD cards, and some take the HD/SD card, and they are not interchangeable, the SD will not work in the HD/SD device and vice versa..........hope this helps........
Aug 22, 2009 | Motorola Mobility Car Charger For KRZR...
Motorola k1 cannot format unformatted memory card
sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Jun 04, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
How to change memory cards 2 similar razor phones
yes you can transfer your memory card to other phone if they have dsame size of memory card, is it MMC, SD, MINI SD, MICRO SD,
May 03, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Formatting the mini sd card
Don't know if your sansa supports from the settings, info tab to select sd card and format, if not attach to pc (settings usb) and the first memory displayed will be internal the second will be microsd card.
Apr 10, 2008 | SanDisk Sansa e250 MP3 Player
Memory card for motorola krzr k1
try formatting & inserting it again.......
it may solve ur prob
Dec 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
SD Mini card
Nov 16, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
