SOURCE: 2002 Chevy Trailblazer idle down cut off when heater or AC is on
most of the time computer just needs to relearn itself. should straighten itself out after a drive.if not try cleaning the throttle plate
SOURCE: 1995 chevy g30 van
If vehicle was left outside or in an unheated garage, there is a strong possibility that condensation has contaminated your fuel. Easiest way to check is to remove fuel filter and pour contents into a glass jar. If you see two different layers of liquid in the jar, the bottom part is water. Replace with new filter and drop the tank. Remove sending unit. pour contents into a large container and clean out inside with clean dry rags. Remember, fuel is dangerous to work with and fumes travel pretty far on the ground. So, no open flames electrical stuff, cigarettes etc for a good perimeter around work area. Generally, you can re-use top 3/4 of fuel you removed by syphon. Don't use remainder in your vehicle. Part can be used for lawnmower etc as long as you only take the part above the water line.
SOURCE: 1998 chevy malibu dies while driving down road
that would probalbly fuel filter or a blockage in the tank
SOURCE: suburban stalls while driving
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
SOURCE: 2005 Chevy Surban blower motor resistor
mine did the same thing. It was the gears breaking off in the resistor. However, the wiring harness and resistor melted inside of the dashboard AND DID NOT trigger the fuse... causing a safety issue. This was this past month. I notified GM and the National Highway Traffic Saftely Administration hotline located in the owners manual. They are not tracking this problem to see about safety recall. If you have this issue, you need to ntify them as well at their toll free number
