Technics SL-10 does not rotate
This is a linear tracking turntable with the tonearm in the cover, given to me in virtually unused condition. With everything connected properly, when a record is placed on the platter, the cover is closed and the "start" button is pressed, the platter does not rotate. Nothing happens, except the "repeat" LED begins blinking. If I press the manual button with the cover open, the platter rotates correctly - but of course the tonearm is in the cover, so you can't play the record. The only thing I can get with the cover closed is the blinking "repeat" LED. I've tried pressing the buttons available to me in various combinations and looked for other switches or buttons, all without success. I've also checked to see if anything is interfering with the tonearm, but can find nothing out of place. This is conceptually a very simple turntable, only a few buttons and nothing else. I have a manual, and I am doing what it says to do, but no joy. I hope someone out there has experience with this turntable and can tell me the secret to making it work, or whether it's FUBAR and I should give it up. Aside from the fact that it doesn't work, it is a very nice piece of equipment and I'd like to use it if I can. Thanks in advance Damon Fever
  • 1 more comment
  • Damon Fever Sep 11, 2007
    Thanks Shuttle83; that makes sense. I've had the cover closed, but I will look for the switch and make sure it is triggered.
  • Damon Fever Sep 12, 2007
    I tried the turntable again last night, paying close attention to closing the cover, but no joy. Pressing "start" (with a record on) only produces a blinking "repeat" LED and no movement of any kind. I poked and prodded everything I could find (short of dismantling) that might be connected to a switch, but nothing changed. The cover closes and locks solidly. If you think this switch is where the problem is, I guess I will have to disassemble the base to find it. I'm traveling for a week or so and won't have a chance to do that for a few days.
    OK, thanks. At least I can now open it up with some idea of what to look for. I appreciate it.
    Genius:
  • 1,139 Answers
OK a blast from the past. There is a switch that is in the base which senses that the cover is closed and this unlocks the arm and disk motor can rotate. The reason that the disk rotates when the cover is up is because this allows the disk to spin up to speed before the arm comes down. Once the cover comes down the switch unlocks the arm and the arm then moves this switch also can stop the disk if the arm does not unlock.
Posted on Sep 11, 2007
  • Henry McKelvey
    Henry McKelvey Sep 12, 2007
    Hello Damon,
    I believe the switch is the problem, The model I have worked on in the past had a manual switch but I have heard of those having a magnetic switch.
SOURCE:
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
Feb 02, 2012 | Audio Players & Recorders
Arm weight needs adjusting...albums are skipping. how do I do this? thank you.
If you have a guard for the stylus, consider using it or be very careful with the following.
To balance the tonearm, rotate the counterweight at the back of the tonearm one way or the other until the arm floats - doesn't go up or down, just sits there level. Set the scale to zero.
THEN, rotate it inward (clockwise when viewed from the back) until it is correct for your cartrridge. If you're not sure of a correct setting, start with 1.5 gm and see how that goes.
If the TT has an anti-skate adjustment (a small knob with scale around the base of the tonearm, set that to whatever you set the tonearm pressure for.
If it still doesn't track OK, add pressure in 1/4 gm increments but do not exceed 2 gm in all but very rare cases.
Jan 27, 2011 | Technics SL-BD22 Turntable
When i play a record it skips and when i play it on another turntable the same record doesnt skip
Hi, most likely a worn stylus or the tracking weight is set too lightly. Adjust the balance weight at the back end of tonearm forward slightly. If no weight adjustment available put a very small coin on the end of tonearm above the stylus. [email protected]
Jul 08, 2010 | Technics SL-1200 Turntable
Suggested lubricant for Technic SL-5 linear tracking tonearm
technics used special grease for lots of their products, any good quality grease will do but use sparingly
Apr 07, 2009 | Audio Players & Recorders
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Using Technics SL-B2
check the antiskating. then i don't know.. maybe the tonearm has to be calibrate
Feb 18, 2008 | Technics SL-1210 Turntable
562 people viewed this question
Ekse
 Grubhead
Grubhead
