Hello you can download the manual here:
http://www.jeep.com/en/owners/manuals/
Select year and model, and download the manual.
You will need a free PDF reader to read the file content:
http://www.adobe.com/downloads.html?promoid=KAWQL
The aircon system has to be filled up once a year or to be checked the level in the system. If low level in the system, its not cooling.
Almost every auto repair shop has the machine to fill up the system again. This is not a do it your self job.
This will cost around 200 dollars, but only if not something else is malfunctioning, electrical or mechanical.
I recommend to visit a specialist in aircon system, for better and cheaper fault finding.
Good luck
SOURCE: 2003 hvac blowas hot air and compressor wont come
you havea broken cable to the vent blend motor or a bad vachum motor.
SOURCE: 2003 jeep liberty bypassing ac compressor
if ac gas pressure is low in ac lines, system may not work correctly. once i found main reason of having non operational compressor on jeep cheorkee was only the loss of gas inside AC lines. plus please check for AC relay under hood. it can go broken.
