Question about Compaq Presario M2000 Notebook
New battery will not charge
I have a three-year old compaq M2000; the factory battery had steadily declined until it would hold only a few minutes' charge, so I replaced it. I plugged the computer in to charge with the new battery in place, and went to sleep. In the morning I unplugged it and turned it on, to find a low battery warning: only 24% charged. I ran it down, and plugged it in again, then left for work. Returned twelve hourse later, and still-----24%! Help?
  • typist321 Sep 13, 2007
    Yes, I'm using the adapter which came with the computer. The cable has been repaired at the end which plugs into the computer, after the wires got disconnected or shorted out through wear-and-tear. The thing is providing enough power, s far as I can tell.
  • jklkdblm Mar 02, 2008
    I bought a refirbished laptop and have been having trouble with the battery. I've only had it a few months and the battery came with a 30% charge. From then the battery has declined to a 20% charge. I've never been able to unplug the computer from the adapter without losing power. I recently purchased a new battery and I recieved the same results. The new battery started at a 20% charge and has not gone up at all.
    Problem Solver:
  • 7 Answers
Thanks Carl97,
For the DVD its Great. I know its not 100% related but
the main reason i post here is to say that your website solved my problem with Power Supply, but strange as it was it turned out to be the issue you mentioned regarding the LCD Screen cables comming lose.
Happy New Year
Posted on Jan 01, 2008
  • larslarsen Mar 17, 2008
    It sounds like you have a Faulty DC Socket and Needs replacing
    Problem Solver:
  • 12 Answers
It could be a Problem with Your Powerjack and may need replacing. You can diagnose this at my website: there is also a useful DVD there to show you how to open and repair a Power Jack.
Or DC Socket.
Posted on Dec 17, 2007
  • 181 Answers
Hi, Well, first, do you have the correct ac adapter?It's possible to have an adapter that will run the system, but not provide enough juice to run the machine AND charge the battery. Did you replace the battery with a brand new one? Thanks
Posted on Sep 10, 2007
Cordless drill - model KC9682C - probably 8 years old. Stopped working shortly after a battery re-charge. I'm guessing it's the battery. It charges for a few minutes then the red light goes off. Could it...
If light is on charger the charge is fine. You could verify using voltmeter it should put out = to what it says on the back of charger 12-18 volts or so.
Most likely battery is shot after 8 years they just dont' hold a charge anymore and they often will only charge for a few minutes when the chip in the computer tells the charger to shut off due to defective battery.
compare prices of new drills and new batterys sometimes new drill is not much more. Try ebay and harbor freight for ultra low priced batteries.
Mar 03, 2011 | Black & Decker Drills
When i boot up, my Compaq CQ20 displays the message that the battery has low storage capacity. Battery time is now down to 15 to 20 minutes at full charge.
If you laptop is more than two years old then it is possible that the battery is faulty as many of the compaq laptops have poor back up battery orr quality retained.
Check the adapter on the PC , check if the adapter charges the battery to full capcity , now if this charge wont lat more than 20 minutes , you might need a new one.
Discharge the battery fully and charge few times as the last resort.
Feb 23, 2011 | Compaq Computers & Internet
My acer aspire 5535, amd turion x2battery runs out faster than it used to
The battery starts a slow decline over months and years, eventually you will notice the time between charges gets less and less until you are down to minutes, this quite normal for these batteries. The average life span is one to three years for most batteries before replacement is required.
Jan 25, 2011 | Acer Aspire 5500 5570-2609 Laptop
"battery doesn t charge how do I know if the power cord or the battery is bad on my Presario M2000
If the battery is over a year old then it could be dead.Anything over two years I would bet on it. Usually the power bricks are very reliable. To check it you just need to put a power meter on it and check the voltage against what is printed on the brick. It should be slightly higher.
Without a meter it is pretty hard to check. You should get some indication that it is plugged in. It may have a power light on the brick or the laptop that shows it on even if it wont charge.
Mar 23, 2010 | Compaq Presario M2000 Notebook
Battery does not charge
Will the old battery (that you are replacing) charge up at all? If the old battery charges but the new battery will not, then it's likely a bad replacement battery.
To rule out the possibility of a corrupted battery meter inside of windows, you may wish to leave the laptop on battery power only, until it dies. A 5% charge will usually only grant you about 20 minutes of laptop life maximum. Since you left it charging all night, you should get a few hours of life before it dies. If you get a few hours of life, the battery meter software is corrupted.
Most likely though, the replacement battery is bad.
Sep 02, 2009 | HP Compaq Evo n610c Notebook
Turn on a s/h presario m2000 and it asks for a password of which i dont know what do i do`
try pressing esc. two times.
Or type admin for username or admin for password. Or try password for password.
Jul 04, 2009 | Compaq Presario M2000 Notebook
Have three vertical lines on my laptop Acer Aspire 3000
This problem is possibly due to blown diodes in the LCD panel.
Apr 19, 2009 | Compaq Presario M2000 Notebook
Compaq m2000 battery not charging.
battary nikal ke dubara lagao
tinner dalo lens main.
Mar 07, 2009 | Compaq Presario M2000 Notebook
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook. has decent deals on these adapters.
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 25, 2009 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
100 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
