Question about Toshiba SD-4900 DVD Player
Dvd player not working
I have a toshiba sd 4900 dvd player it worked fine for a while but now it wont play at all, i took the cover off and saw that the disk doesnt even spin when you press play..it also takes like 30 seconds to open and close. I cleaned the lens so i know thats not the problem, i also made sure there wasnt any wires loose.is there anything i can do to get the disk to spin?
  • 752 Answers
If the disc isn't spinning, and you have cleaned the lens (using a proper method) then it is likely that the laser has failed. The disc usually won't spin until the laser has sent/recieved a pulse from the surface of the disc. A new laser is usually about the cost of a new player.
Posted on Sep 10, 2007
SOURCE:
Does this dvd player play 720p or is 480p the best I'm going to get?
Hi there, as far as your dvd player it will not up convert as suggested with SD stands for standard deffinition,. However some tv's will up convert slightly. Also note that Svideo is a little bit cleaner and crisper of a picture. still the HDMI is the highest deffinition yet. I hope this helps, another note though,. If there is the the green, blue, yellow cables, not the red white yellow, those are a little crisper yet.
Feb 06, 2011 | Toshiba SD-4900 DVD Player
Toshiba SD-K625 5 disk player won't play DVD but will play CD
Could be that the laser mechanism has lost its ability to focus properly on the dvd disks. U might want to try a firmware upgrade just in case the player has corrupted software. If not effective, then it is time to go shopping since a repair is not cost effective.
Mar 31, 2017 | Toshiba SD-K625 Multi-disc DVD Player
The remote control on our Toshiba SD-690KA player has stopped working. Replace batteries... still not working.
Took the batteries out... pressed each button on the remote individually... put batteries back in. It works fine now.
Jan 21, 2010 | Toshiba SD-690KA Player
Dvds wont play
Check out the link I have posted below.
http://www.homemovie.com/compatibility.htm
according to the list, your in the 5% area of dvd players that won't read burned home made disks-DVD's
Sorry Pal your in the same boat as myself.
I have a Toshiba SD-2107 --- We're both aout of Luck :(
Looks like it's time to invest in a new DVD player.
Aug 05, 2008 | Toshiba SD-2109 DVD Player
Toshiba SD-4900
Try this, as posted on www.videohelp.com:
Put in DVD.
When you get region whine message press: [menu] [1] [play]
Disc should play, but with region message still up.
Press Marker then Clear. Message is now gone.
You can go to the menu for setup, or keep watching the movie.
Mar 08, 2008 | Toshiba SD-4900 DVD Player
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
DVD PLAYER
Hi Koji, My Toshiba DVD player does the same. It stops playing the disc, and the icon for incorrect disc displays. Often I cannot even start a movie. I keep getting BAD on the readout display also. I try hitting the player, or the stand in which the player is sitting, and sometimes it goes away and the movie plays. I will never buy Toshiba again.
Dec 25, 2006 | Toshiba SD-3980 DVD Player
Toshiba SD-4900 DVD Player Logo
283 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
