Question about Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES15 Hi guys, Was recording to DVD and the next day went to play the DVD but an error message saying something similar to "information was lost and disk removal will loose information, press enter". Now regardless of what type of DVD is inserted or even if no disk is inserted the player noisily tries to load the disk and eventually says "no read". Any suggestions would be great.
  • 1 more comment
  • J. S. Nov 01, 2007
    I'm having a similar problem, error message U61 keeps showing up. The problem started after buying some different disks than I usually used, (Memorex +R) so got some more Sony (-R) which have always worked perfectly before but the problem now persists.
    I've cycled it through Self Checking 100 times with disks inserted and not, blank and not, recorded and not, no luck. I've unplugged it for hours, no luck.
    Disks recorded before problem: about 450 over 6 months. Not bad but a far cry from the performance I thought I'd get from this unit.
  • PP R Feb 28, 2008
    MY PANASONIC DMR-ES15 IS TOTAKKY OUT OF PHASE. STARTED WITH NOT BEING ABLE TO FINALIZE A RECORDED DISC AND NOW WON'T RECOGNISE ANY DISC.... RECORDABLE OR FACTORY MOVIE I HAVE DISCONNECTED AND LEFT AND THEN RETARTED HOPING TO RESET BUT NO. CAN YOU TELL ME HOW TO RESET IF IT IS POSSIBLE.
  • jlmundy May 11, 2010
    Interesting. I experienced this problem after trying to record to a +R DVD (same as PanaFan777). I've unplugged it, I've called panasonic who says send it in for service. It's 13 mos old so out of warranty and will cost me $130 to fix it from Panasonic. Any other ideas?
    Problem Solver:
  • 12 Answers
Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
Posted on Sep 28, 2007
Error reading any dvd disks
Have you tried a DVD+/-RW ?
The noises that you are hearing will be the spindle motor trying to spin the DVD as the lifting presentation tray for the read/write head has not located, if the media is not spinning this will never be able to read the lead in on any DVD as it has not presented the disc in the correct place.
If is is out of guarantee then I suggest that you check to see if the DVD is spinning by removing the top cover with the power OFF then eject the tray and try to load the media a small touch of the DVD in the clockwise motion should cause the media to start spinning, this is for diagnosis only if this is the case then the spindle motor will need changing
May 28, 2010 | Panasonic DMRES15 DVD Recorder
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
Since it went into "disk recovery mode" it now will not play dvds
Got the same problem. Happened 2 months after guarantee expired. **** machine. The only good thing is the harddrive and that is made by HITACHI not Panasonic! I go Sony next time. Panasonic quoted £200 plus to fix the problem. I only paid £220 when I bought it new.
Sep 13, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Bad disc-error
sometimes the disks in the camcorder can get break down. its known problem is no working for long time. if everything on the disc are important for you  pls go to service. dont touch anything that you dont know.
have a good day.
May 28, 2009 | Samsung SC-DC164 DVD Camcorder
Invalid disk
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's but avoid memorex brand. Usually any other cheep brand will work.
May 04, 2008 | Gateway AR-230 DVD Recorder
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
EWR20V5 DVD Recording Error
The disc must be DVD-R with an R4.7 under the logo and they MUST be 4X or 8X specific .... the cannot be 1X to 8X or 1X to 16X or note up to 16X .... the disc box must state 4X or 8X ONLY .... and yes they are hard to find for sure.....
Aug 24, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Programming errors
Several things to check 1) Your time - set it manually and remove the automatic time set 2) Try manually recording even a few min of anything (just put on channel to record, press DVD button and DVD Record button) - does it give you an error message on that disk? If so it might be because you are using 16x and machine sometimes gets messed up and won't record on those speed disks - same with +R sometimes does this - try recording on 8x -R ones. Hopefully this helps - if not try unplugging unit from wallsocket and leave off about 30min then try setting program again etc (plus current local time) and use a new disk and see if problem still occurs - sometimes just unplugging it "resets" everything and then starts working again.
Jan 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Panasonic DMR-ES10 DVD Recorder Logo
465 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
