Question about Philips DVP642 DVD Player
DVD movie won't eject
I just finished watching a movie and the disc won't eject. First, tray came out empty. Now it won't open at all.
  • 752 Answers
Unplug for 5 minutes then plug back in and try again. should reset itself and work.
Posted on Sep 10, 2007
SOURCE:
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
How do i eject a disc
If the tray fails to open when hitting the eject button on the face of the drive; take a paper clip, straiten on end push it into the small hole on the front of the drive. This will eject the tray and allow you to use the Reader/Burner. Try grabbing the tray and move it in and out aggressively, and do that about 10 times to loosen up the drive motor and clean out grime that collect on the internal parts.
Jan 08, 2014 | Gateway Computers & Internet
LG v181 won't eject - it tries to load even when there is no disc and won't slide out the tray at all.
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
Dec 23, 2012 | LG V181 DVD Player/VCR
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
I HAVE A MOVIE STUCK IN THE CONSOLE
well u could use a hairpin to pry it open...
Nov 13, 2009 | Microsoft Xbox Console
Disc won't eject & stops working
your disc tray is jamming on an intermittent fault and when it does work it is recording each time the eject botton is being pressed so when your watching movies or playing games it tries to eject the disc tray and causes an automatic shutdown it will definately neet proffesionally repaired and should cost about 30-40 pounds and get a guarantee with it bacause these faults can come back to haunt you.
Oct 06, 2008 | Microsoft Xbox 360 Console
Not closing
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Oct 05, 2007 | Sony DVP-NS305 DVD Player
Can't get disc to eject
open the unit. locate the motor which performs the task of ejecting tray. now spin this motor by hand. wait...5 discs (disc-or did you mean tape?) in unit at once? Are you sure? Well Hello Dolly!
Aug 13, 2007 | JVC HR-S3911 S-VHS VCR
Philips DVP642 DVD Player Logo
216 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
