Question about Canon Speedlite 420EX TTL Flash
Speedlite 420EX Suspect Main Flash not Firing
I have a 420EX that appears to not be firing the main flash. It will charge up and you can fire the pre-flash manually on the flash and also on my Rebel XTI. My camera will not remember the pre-flash, which is marked with an asterick that is seen in the view finder. All other functions seem to work on this flash, including range adjustments. Is there a pin on the hot-shoe where the flash will send information back to the camera? I'm wondering if this could possibly be the problem. Any help would be much appreciated. Thanks, Richard
  • mike2089 Dec 25, 2007
    Hi I have the same problem with my 420, the flash light turns green after power on, and recycle, but within 5 seconds it turns red, the preflash works, as well as the rang info. But when I take the picture the flash does't fire.
SOURCE:
  • 9 Answers
SOURCE: xti rebel 6 mths old - flash will not pop up
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Posted on Feb 19, 2008
  • 9 Answers
SOURCE: No flash popup on my rebel XTI
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
  • 23 Answers
SOURCE: flash not firing properly
Could be the metering mode you are in. Could be the subject is too far away. Could be ISO is set wrong. Could be the lens aperture can't open up enough. Could be the exposure compensation isn't set correctly. Could be FE Lock is still on and the composition has changed. Does the <flash> icon continue to blink? Then you are too far away.
Posted on Dec 06, 2008
  • 25 Answers
SOURCE: I have a canon rebel
I had the same problem.
Look closely at the hotshoe. Inside it, way over to the side, under one of the tabs on the side, is a tiny metal strip. When you attach an external flash, the strip is pushed down and holds down a tiny button that deactivated the pop-up flash. The strip can get bent so that it doesn't let the button come up even when the external flash is removed.
Very gently take a fingernail or a jeweler's screwdriver and run it underneath the metal strip. I had to do it a couple of times to get mine working again, but it's working great now!
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: camera does not fire external flash
Also be certain that the flash is screwed onto the shoe as tightly as possible.
Posted on Feb 28, 2009
Tip
How to Disassemble 420EX Flash
I wrote up on instructables how to disassemble this flash for anyone needing a guide.
http://www.instructables.com/id/How-to-Disassemble-a-Speedlite-420EX-Flash/
on Dec 04, 2007 | Canon Speedlite 420EX TTL Flash
The 580EX is firing but images comes out completely dark it just started happening in a session around 2 hours ago........i put it on another camera the 40d still the same problem what can this be?
When the flash mode TTL. Then this situation can occur if the proximity is working with other studio flash light traps. Your work makes flash another flash while TTL metering. And when is your main flash another flash did not have time to recharge.
Sep 18, 2010 | Canon SPEEDLITE 580EX TTL Flash
When fired the unit appears to discharge all the power but the photo is completely under exposed
If the flash fires but the photos are dark, this typically indicates a fault with one of the following:
- fault of the main transistor that triggers the flash
- fault of the fiber optic cable that connects the flash head with the body
What you have to understand is that when you see one flash in operation, on a properly functioning unit there are actually two flashes in sequence. The first, pre-flash is used for metering the scene, then the follow up is the actual flash that gives the light in the photograph. If the transistor is faulty then it may just discharge the capacitor during the pre-flash, not leaving any energy left for the main flash. If the fiber optic cable is broken (it is very fragile), then the metering stage fails and the flash logic decides to abort the main flash.
Jul 12, 2010 | Canon Speedlite 580EX II (1946B002)
Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Nov 03, 2009 | Canon Speedlite 430EX TTL Flash
580EX speedlite not firing
Does the pilot lamp light up? If so can you fire it manually by pressing on it? If the batteries are low it may simply just be taking a while to charge, the camera will not wait for it to be ready to fire and it may seem to be not working. If your flash can be fired manually however, there may be a problem with the cameras shutter or the hotshoe. You can do a basic check by pressing the star button at the rear of the camera, you should get a pre-flash. If not, there is a problem with the cameras hotshoe which you will need addressed by a service centre. If you get a preflash you can next check the cameras shutter by setting the second curtain to sync with the flash. This can be done via the cameras "Custom Function" menu, c-Fn 15. Set the camera to TV mode and chose a 1 second exposure. Take a shot with the flash attached, if the shutter is working correctly, the flash should fire a pre-flash and then a main flash. If it doesnt, the switch inside the shutter is broken and the shutter needs to be replaced. This is a pretty labour intensive repair and you may consider an upgrade as more economical.
Apr 14, 2009 | Canon SPEEDLITE 580EX TTL Flash
Canon flash speedlite 550 ex ttl
Send the flash back to canon for Service this is not something that can be fixed in this forum. Do not use the flash the burning smell indicated a potentially dangerous problem and fire hazard.
Jan 09, 2009 | Canon Speedlite 420EX TTL Flash
Remote Firing of Flash Units
The EOS 40D does not have a transmitter built in. The remote flash units must be set to "Slave" and the on-camera external flash unit (eg Speedlite 580EX) or transmitter (ST-E2) set to "Master". Note that the Speedlite 430EX doesn't have the function to act as Master and you need a minimum or the 580EX or a ST-E2 speedlite transmitter (or similar) as Master/s.
Jul 29, 2008 | Canon EOS 40D Digital Camera
420EX Flash and Preflash Shooting all power
I have exactly the same problem with my 580EX flash, can you let me know if you find a solution?
Thanks!
Joelle
Jan 05, 2008 | Canon SPEEDLITE 580EX TTL Flash
Canon Speedlite 420EX TTL Flash Logo
83 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
