Question about Panasonic CT-27G14 27" TV
Tv my tv blows the fuse every time i switch it on ive changed twice still the same thing it all started when there was low power in my area and as soon as i nlight the heater the tv went dead coz even my amplifier could not switch on properly due to the power being low voltage
  • BEANZZ Sep 16, 2007
    IWILL TRY THE SOLUTION IWLL GET BACK TO YOU
Check the transistors around the power supply, most likely there is one that is that is shoted out.
Posted on Sep 10, 2007
SOURCE:
Fix high voltage shutdown
be looking at the system fuses..or power relays..
Jan 08, 2014 | Sony BRAVIA Televison & Video
My 1997 Chevy suburban k1500 5.7L keeps blowing the 20-A ENG 1 fuse
I had this same problem with a 1997 Z71 K1500. That fuse was receiving power from the ignition switch in my truck. After putting 4 ignitions in it in 6 months, I finally figured out that every time I put the transfer case in 4Low, the service engine light would come on & the ignition switch would go bad soon after. The electric motor that engaged transfer case was bad. Every time I engaged 4 Low, It would throw power surge to ignition & blow it up.
Sep 22, 2013 | Cars & Trucks
19 in lcd sharp keeps blowing fuse
check the primary section of the powersupply mostly diodes and transistors inside and alo there filters.
Feb 06, 2013 | Sharp 32R-S50 32" TV
Ignition fuse keeps blowing, sometimes I drive 130 miles till it blows n sometimes 1/4 mile and sometimes as soon az I replace it it blows orther times I put a new fuse in and the fuel pump runs and when I...
I'd replace the fuel gauge sensor as a first thought, however, before doing that, I'd meter the sensor the times that it blows immediately.
You may want to check and see if it blows at a specific fuel level.
Trace the wiring to the fuel guage itself and make sure the wire isn't intermittantly shorting somewhere like where it runs through the headlight (if it does) and where it goes into the fuel gauge (or low fuel light).
You seem to have tracked the problem to the root area and just need to isolate it to the specific area.
Jun 28, 2011 | Harley Davidson FLHRS - FLHRSI Road King...
My Philips 42"lcd tv modle
The parts on the Power Supply module will be to difficult to locate so the best thing is to replace the power supply board. The power supply is in stock at www.shopjimmy.com
The price is $83.96. Just enter your model number and follow the directions.
Nov 28, 2010 | Philips 42PF5421 42 in. LCD Television
1989 honda accord headlight fuse blows as soon as replaced
you more than likely have a shorted wire in the headlight harness... you will have to check the wiring from the headlight bulbs to see if it has been pinched up against a sharp metal edge causing a grounded wire, or maybe the harness was crushed by an improper headlight installation.
Jan 12, 2009 | 1989 Honda Accord 4 Door
My phillips 42" flat screen model number 42pf7621d/10 keeps blowing the fuse in the plug usually after we have turned the tv off and its in standby mode or overnite when we sleep ive just change...
What is rating of fuse in your TV like amperes and volts.
There is Thermistor in TV for degaussing the picture tube while in start up. This part requires heavy current to work for a second or two.
You can increase little bit current rating of fuse to avoid blow off.
Oct 01, 2008 | Philips Televison & Video
Blows fuses repeatedly on IWT3206 model
when electrical storm was going on the t.v. was on ? if it is was then return electrical / heavy lightning it may burn the parts.shorting through your mains and anteena conections, please clarify
Jun 24, 2008 | Televison & Video
Its actually a 13GP244
you need to check the power supply area. usually when a fuse blows, that means the bridge rectifier is blown or the ic in the power supply area is blow too or both are blown.check there..good luck
Apr 04, 2007 | GE 13GP243 TV
Panasonic CT-27G14 27" TV Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
