Question about Dryers
Simpson Clothes Dryer is smoking from the back
But it still works... Are there any obvious things that might be causing this? Especially ones that I could check easily. Thanks Rodney
  • GeckoMin Sep 24, 2007
    took it into the back off and couldn't see anything, so I then took it to the repair man he simply applied some oil to the motor (and somewhere else - drum I think) and cleaned the flint out of the motor...
    Seems to have done the trick
    R
My simpson dryer not comming hot
Posted on Dec 19, 2007
  • 725 Answers
You should check your vent. is your vent in the front or back as some Simpson can vent in the front or back. You may be pluged with lint. safety therostat should shut down if too hot. but the lint may catch on fire. please check it before you use it again.. let me know what you find out? krazytech
Posted on Sep 10, 2007
SOURCE:
How to wire Simpson 1200S dryer motor
Check with Simpson directly to obtain the diagram.
Jun 10, 2014 | Dryers
Air no longer venting out back of dryer
sounds like the fan not working.
Apr 06, 2013 | Dryers
Clothes dryer stopped working while it was working Simpson Sirocco 455, what could be wrong?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 26, 2011 | Dryers
Where does the spring clip onto for a simpson ezi loader 5kg clothes dryer
Hi, I too have one of these dryers & have also found a spring, along with alot of fluff, some staples, & remains of the rear seal inside the dryer. must be a manufacturing fault by the looks of things, the spring was bent & twisted & must hold the seal in place. I would say it will need to go to the repair people for replacement. also note the fluff (remains of the seal) had an area where it had burnt from the heating element & could cause a fire.
Feb 17, 2011 | Dryers
Simpson Maxidry 1200 S Clothes Dryer. Dryer spins, Blower working, but heater doesn't work. I've got the element out & it checks ok. What next please?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Dryers
Fan in the Simpson Sirrocco 500 clothes dryer doesn't work.
It is both easy and cheap! I do believe there is a cover on the back of this model hiding the drive belt for the fan. It has iether broken or come off. If it has come off and lint or something of the like was not the cause it is quite possible that it has stretched and will require replacing =)
Feb 25, 2010 | Dryers
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Clothes dryer stops
sounds like the drive belt has stretched, or the auto tension is low.
disconnect power and remove back cover, clean inside around motor resitor block wires, and inspect/ replace faulty components. good luck!
Jan 30, 2009 | Dryers
Simpson Clothes Dryer wont start without assistance
your dryer has a start assist compressor go to this site to see it and that could very well be the problem. www.repairclinic.com/SSPartDetail.aspx?s=t-39p400-%3d%3db166i938994%PartID=938994
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
Dryers Logo
663 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
