Question about Whirlpool GD2SHGX Refrigerator
Refrigrator I need to know how to fix the water to my refrigrator. The water line broke off in the door as we were moving to another hous.
  • 725 Answers
If you are lucky you can use a John Guest Push-Fit" connector to reconnect the two ends together..if you have enough hose to work with ..sometimes you can pull on the end that goes into the refrigerator cabinet to give you a little more hose... let me know what you do? krazytech
Posted on Sep 10, 2007
SOURCE:
Internal waterline broke
i would need a model number because in most cases if the water line broke in the door, you would have to replace the whole door assembly.
Dec 30, 2012 | Refrigerators
GE side by side refrigerator freezer door water tube broken
You need to contact a seller of GE parts with the model number of your fridge and order a replacement tube, these can be a pain to fit but not too hard.
Mar 10, 2012 | Refrigerators
Have a GE hot point HSS25GFTABB, removed doors to put inside house after a move and the ice maker works, but when you fill with water, it runs down the line dripping at the bottom of left door
Inspect the line crefully at the bottom of the door where it connects to the cabinet supply. The line may have been damaged when and if the doors were removed.
HOPEFULLY it is a small nick in the tubing casuing the water leak, and not the line inside the freezer door as the water line is foamed into the door and the entire door would have to be replaced to resolve an internal leak.
The coupler at the door connection is a push-lock syle coupler and to seperate the line you need to press the white collar into the blue barrel connector to relese the tension.
Jun 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
We have a ge side by side refrigerator...while moving it we broke something off the back...it was like a little tube or coil...it was really short..maybe 4 inches...i think it led to the icemaker...i dont...
Possibly the water inlet valve? Look at the water line on the back that goes up the back to the ice maker. The bottom end should be connected to the water inlet valve. This is also where the water supply from the house connects.
Oct 02, 2009 | GE Profile PSI23NCR Side by Side...
I have LG french door refrigerator
here is a website that may have the literature you need
http://www.lge.com/us/support/product/support-product.jsp
Jun 12, 2009 | LG LFD25860
Leak inside and outside of refrigrator
Hi, it is worth fixing. There is a drain plugged in the freezer. Get me model # and I can assist you further on this matter.
Thanks
Vic
May 22, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Ice maker water line freezes
Hi, it sounds like the water valve is leaking just enough to cause the water to freeze in the inlet tube. This is the most common fix.
If I can assist you further, please let me know.
Thanks
Vic
May 15, 2009 | Refrigerators
Hotpoint refrigrator
On back of refrigerator there are 2 water solenoids. It is possible that the solenoid for the water in the door has a magnetic plunger sticking and not allowing the water to travel through the refrigerator to the water dispenser. Unplug the refrigerator first and turn water supply off. Then check or change the pair of solenoids. Let me know if this helps, Sea Breeze
Feb 08, 2009 | Hotpoint HSS25GFP Side by Side...
Kenmore fridge icemaker doesn't work after move
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Oct 11, 2008 | GE Profile PSI23NCR Side by Side...
Water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Jul 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool GD2SHGX Refrigerator Logo
221 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
