Question about Car Audio & Video
Honda accord speakers
Got car back from stepson and the speakers don't work (cd or radio)....the unit itself is working, just no sound.......checked owners manual and there is no mention of a separate fuse or circuit breakers for the speakers.......any hints?
  • Anonymous May 23, 2008
    The speakers on my 2005 honda Accord all suddenly stopped working. They are the factory speakers and radio. The radio seems to still be working as all the stations still appear on the screen. I have no idea where to start looking to solve this problem.
He might of blow you speakers, by having them to loud and he over powered the speakers. blow coils.
Posted on Feb 08, 2008
Ground wire not strong enuf
Posted on Jan 12, 2008
  • 752 Answers
Is it all factory equipment? Perhaps he had a different system put in then uninstalled and the factory gear put back in....but not properly. Or if you meant he only had it for a day or something then perhaps he was playing it too loudly and blew the internal amplifier out. Factory decks are usually not worth repair so a new deck will be likely required. Any decent car audio shop should be able to do a few quick and dirty tests at a minimal (if any) cost.
Posted on Sep 10, 2007
No sound radio honda accord 2004
Either radio is bad, or you have a loose connection to speakers, or poor ground connection at the radio. If a poor ground connection, the radio will intermittently not work also. Since radio continues to work, but sound does not, it is probably a bad audio circuit in the radio itself.
Apr 29, 2012 | 2004 Honda Accord
I have a 2003 Honda Civic EX coupe. Installed aftermarket radio cd player and the cd works but the radio does not. The issue is not with the new unit as the previous player's radio would not work either....
If you're getting power to the CD player then there's power
to the radio. The antenna involves the grid on the rear window,
an antenna coil and cable to the radio. You can check the
grid for a break and if it's small you're auto parts store will
have a repair kit. My 05 Accord rear window defogger did
not work and it took Honda 2 attempts to repair it. Other
than checking the grid I would bring it to the dealer.
Feb 03, 2011 | 2003 Honda Civic
My 2005 accord's radio will power on, but nothing is coming out of the speakers. at one point the speakers would produce a sound and then cut off and even after having this problem was able to turn off...
If you remove the radio, you could check the speaker wires with an ohmmeter to see if any of the wires are shorted to chassis ground. If they are not, the radio is the problem.
Sep 14, 2017 | 2005 Honda Accord
Radio work with all the light but no sound, this is on 2003 Honda Accord.
because the light on the radio come on with dash lights doesn't mean the radio is working,check fuse for radio,if its good,check for power at radio connection,if you have power there see if you can see a change in stations when you turn knob,if you do make sure all connectors are plugged in radio,now go to an easy access speaker and plug in a known good speaker
Nov 23, 2009 | 2003 Honda Accord
98 Accord V6 EX CD/Radio no sound despite correct code accepted
check the wirings of your speakers and then check the settings on your radio.
Jun 09, 2009 | 1993 Honda Accord
Front speakers are not working
I have totally replaced my speakers but start with just removing radio to ck. wires to radio and then to speakers. They are color coded with radio wire harness. Do not remove whole dashboard not needed since radios come out fairly easily. Many times speakers just cook in a hot sunny car so need replacing. If new ones don`t work then it`s not the speakers.Good luck. Joe
Mar 19, 2009 | 1991 Honda Accord
Radio does not work with the 1998 honda accord
Mar 19, 2009 | 1998 Honda Accord
Honda Accord 2002 EX-L (Canadian Model)
I think that the problem is in the connection between the cd-player and the radio antenna on the roof.
Jun 17, 2008 | 2002 Honda Accord
Radio Troubleshooting
check the remote wire. if this does not work try cleaning the wiring harness but make sure that the battery is disconnected. if that doesnt work try to trace the wires back to where they start an check for a break in the wire. an have you checked all the fuses under the hood an in the fuse pannel?
May 27, 2008 | 1997 Honda Accord
Car speakers
sounds like there may be a problem with the stereo.
May 23, 2008 | 2005 Honda Accord
Car Audio & Video Logo
907 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
