Question about Sony NW-A1000 MP3 Player
Open up the player
Hi guy i just want to open up the front panel of the player...anyone ha some ideas regarding this?
    President:
  • 1,114 Answers
You need to slide a blunt object such as the head of a drawing pin all around the gap in the case gently prising as you go. The case should pop off. If you are feeling brave you can download the service manual from this link: http://files-upload.com/files/493151/Sony NW-A1000 Service Manual.zip Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 10, 2007
  • Greg Cann
    Greg Cann Sep 10, 2007
    Sorry you will need to cut & paste the link:
    http://files-upload.com/files/493151/Son... NW-A1000 Service Manual.zip
    Best regards,
    Informatica.
  • Greg Cann
    I have renamed the link so it should work this time:
    Best regards,
    Informatica.
SOURCE:
My flat screen will play fine for a few minutes,then goes into Linda Blair mode by turning itself off and on. What could be causing this?
Hi Laurie Crowe,
Ha ha ha... certainly you wo'nt need an exorcist to cure your TV. Please contact a good local TV Tech to handle it. Most probably it is a power supply problem and should be fixed without much difficulty.
Good Luck.
Regards
Aug 10, 2015 | Televison & Video
Pressing the 'open' button on my NAD C542 CD Player no longer opens the disk drawer. Any suggestions to fix this would be appreciated. Regards Michael
G'Day Michael,
Having fixed thousands of CD players in my career, and also being a NAD Authorised service guy from 1989 till recent times, I can comment with some authority to your situation, and correct some of the ill found assumptions given to you already.
This unit uses a KSS213c transport. Very common and used in many machines, also relatively reliable.
The drawer load motor is not shown above. Is will be mounted on the black plastic load assembly. The drive belt/motor for it will be under the tray runners.
If you do not hear the motor run, then it WILL NOT be a broken or failing belt. However, this is the most common problem with this style of transport. I would be checking anyway to see, the load motors do free run fairly quiet with no drive belt connected. Wind the tray assembly out by hand by kicking the gears over to open the draw to see the belt/motor
Because you cannot get it to work from the remote, AND you have "open" indicator on the front panel, it WILL NOT be a faulty front panel button(never seen one fail ever!)
I have never replaced a load motor to a Sony transport. Spindle motors can be a problem, but they never stop working altogether.
I would be checking the tray mechanics, a jam caused by something fouling the gears may cause a fail. Tap the front of the draw as you press eject to see if you can encourage it to work.
Sometimes, small nylon drive pinions can split, the excessive gap in the gears caused by the split causing a bind. Check also for blown pico fuses in the servo drive stage. This will cause no drive to the load motor.
If you cannot pin down the source of the problem, the player IS welll worth repair. These machines sound great and would have cost you a few bucks to begin with. If you need help locating an expert NAD authorised repair guy I can help.
Happy to discuss any of this further with you. As previously direct your comment to me by name. Cheers
regards
robotek
Aug 03, 2010 | NAD C542 CD Player
Won't work
Hi Dmohan2,
Assuming that you are using a windows based system, perhaps you can follow the possible solution outlined to try to solve this issue:
Possible Solution 1: Uninstall and resintall product
1. Click on start
2. Click on control panel
3, Select Add/remove program icon
4. Identify and uninstall google chrome from the options.
5. Restart computer
6. Once the computer has rebooted, go to this website using IE (link provided): http://www.google.com/chrome/index.html?hl=en&brand=CHMB&utm_campaign=en&utm_source=en-ha-apac-ww-sk&utm_medium=ha
7. Install chrome on computer
8. Close IE and start up chrome
I hope the above information helped. Please do let me know if there are other queires regarding this. Also, pls remeber to vote for me if you find this solution useful. Thank you.
Regards,
Technomancer
Apr 05, 2010 | Google Chrome
Hi, i jave just bought a used Pioneer DEH-P8400MP. The guy told me that id did not work no more and that the problem should be the whire to the front plates. Now i habe installed new whires but it still...
The electronics on the main circuit board may be faulty, it can be beyond a home repair I am afraid.
It is possible that the power supply wires were connected in reverse at one time, damaging the circuitry inside.
Oct 24, 2009 | Pioneer DEH-P8400MP CD Player
I have printouts of troubleshooting codes from auto zone the guy had no idea what they meant
I don't know what the codes are, but don't give up all together over one guy. Try another guy... ha.
If you post your codes, maybe someone can help you on here too.
Good luck, I'll be watching for you.
Oct 15, 2009 | 1997 Pontiac Sunfire
E210882 socket type 775, PCIe, DDR2 - Will not turn on
On the Dell board, the
CORRECT pinout for J8H1 is as follows:
1-3: HD LED (#1 is +)
2-4: PWR LED (#2 is +)
5-7: PWR ON/OFF
6-8: RESET
5,16: +5V
10,11,14,15: not connected
12,13: GND
Regards.
Jul 27, 2009 | Dell (E210882) Motherboard
Door does not open after a wash cycle
Hi
the door lock is you problem. just replace and should be back to normal.
regards
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Unlock Deno 2910
Initially, pls try:
  • Verify that the tray is empty/no disc in the player;
  • Shut down/off with the front panel On/Off button and not the standby;
  • Press and hold the Open/Close, Play and Skip Reverse (I<<) buttons;
  • Maintain pressing on the above buttons and Power-ON the player with the On/Off button, (again while still holding the above buttons till the "Denon 2910" disappears from the display);
  • pls wait till LOADING completes and the front panel would display 0:00:00;
  • Using the remote control, enter 7, 3, 1, 9, 4, 6, 2, & 8;
  • The Denon 2910 will go into standby mode. Soon as it is on standby, pls press the Standby button on the front panel;
  • Pls verify region free update by pressing the Stop and Skip Forward (>>I) buttons on the front panel. The display would show “Region_Ax” The x would be the former region number that the Denon 2910 is locked into;
  • Should it not work ouot as expected, pls redo all the above steps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Denon DVD-2910 DVD Player
Looking for service menu of 32Q6TVH LCD TV (NEC and Onida)
HI FRIEND,
I DON'T KNOW THE SERVICE MENU OF NEC BUT TO ENTER IN ONIDA PRESS VSM AND DISPLAY BUTTON SIMULTANEOUSLY, FROM ORIGINAL REMOTE .
JABBAL,
9422117997
NAGPUR
Jan 15, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Sony NW-A1000 MP3 Player Logo
548 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
