Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Infrared broiler won't heat
I cannot get my broiler to fire up, any thoughts?
  • 5 more comments
  • Burn it up Nov 14, 2007
    The broiler of our dual fuel DACOR doesn't work. When I open the oven door a small blast of blue flame leaps out. Also, the digital clock runs very fast. How do I remove it and repair it?
  • roml Nov 29, 2007
    It takes forever for the oven to reach desired temp. Broiler does not come on. (No blue flash noticed)
    also clock only displays 24 hour time (military) and moves backwards when you are trying to set it.
  • arendi Dec 05, 2007
    My broiler also stopped working recently. Could it me an ignitor? All other stove and stove top features are working.
  • quickmix22 Apr 25, 2008
    My broiler also stopped working. while waiting for the service tech, the entire oven stopped. Took 4 visits beforew they could fix it. Now the 2 right burners constantly click after being lit.
  • Anonymous Jun 03, 2008
    Same problem. My broiler in the ERD30 doesn't work. Everything else does. Thanks
  • Douglas Cisneros Dec 20, 2008
    So how did you fix it? What did he tell you to do?
  • Anonymous Apr 28, 2009
    My EDR30 broiler does not turn on, however the ignitor lights. Also the clock switched to military time 2 months ago, powering of the unit does not help. VE
My broiler igniter has gone out once in my 8 yo ERD30. The tech was nice enough to tell me how to replace it myself when it went out again, and so it has. So now I'm looking for the part online! Check out the thread here: http://applianceguru.com/forum1/12935.html
Posted on Aug 04, 2008
SOURCE:
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont heat broiler wont heat
is this a gas or electric range. If it is gas it sounds like a flame sensor is not working. The oven will try to fire up, but if it does not sence a flame, it will shut off again to keep the range from filling with raw gas. Also the easy one, is the gas turned on?
Aug 31, 2012 | Kitchen Ranges
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
No heat when set to broil but the bake turns on the broil element. nothing turns on the bake element. are the wires hooked back correctly?
see the next steps and proceed according with commong sense: God bless you
Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of thi
Jul 27, 2012 | GE Kitchen Ranges
Oven won't heat up when baking (Maytag MGR5775QDS)
Check the Manual/Auto Clock setting to be on Manual not auto . The Oven is waiting for the Right Time to start up .
Jun 13, 2012 | Maytag MGR5775QDS Dual Fuel (Electric and...
Oven wont heat up.
after ignitor glows burners should fire within 30-60 seconds .if not your ignitors are weak (drawing less than 3.5 amps) and should be replaced Hope this helps ,please rate my solution :)
Jun 26, 2009 | KitchenAid KESC307 Electric Kitchen Range
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
Dacor erd36sbk/ng infrared ceramic broiler
Try doing a clean cycle for 4 hours to remove accumulated grease film from the ceramic surface. It worked for me
Dec 31, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Broiler element sparked fire, is the oven safe to use?
any food with an oil base will catch fire on a heating element, it will be fine to use but try to keep food from spilling out towards any heat source, use a try to collect any food drippings or a tray with vents if doing potatoes this will minimize any food dripping on the elements. it will smell for a while on the first cook as the oil will still be present on the element but it will soon burn off.
Jul 03, 2017 | KitchenAid KERC700LBS Electric Kitchen...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
588 people viewed this question
Top Dacor Kitchen Ranges Experts
Steve Allison
Steve Allison
Jaime Hernandez
Ekse
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
