I would check first for the proper guage nails that you bought and then what is the capacity of the tool. You didn't specify the model number but I would think one or the other. then also check for the wood being nailed into. All could lead to your problem.
A nail gun works on compressed air. When you hook the air hose to the gun it fills a cylinder with air pressure. When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail. The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun. If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring. Bostich makes re-build kits for the different guns that you can buy on-line. Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Open the front and clear any jammed nails that are there. Oil the gun, push the drive pin back in if it didn't go back in when the front was off and try again. If there are repeated nail jam issues, try genuine Bostich nails.
The gun needs to be rebuilt. The seals, diaphragms, and valves need replacement. Do a search on the internet for Stanley Nail Gun rebuilding kits. Simple job to do. I did mind last year for under 15 dollars I think. Make sure you replace all the parts including the "O"-rings.
The o-rings need to be replaced and/or the trigger assembly is defective. Look around at local lumber yards for a "Bostich days" promotion. Often with the purchase of a box of nails, the Bostich rep will "service" up to 2 guns for free. If this is not an option for you because of time, you can purchase the o-ring kit and replace the rings yourself. This is not a difficult repair. Also, be sure to lubricate the guns with pneumatic oil frequently as this will keep the rings lubtricated and prevent them from drying out and leaking.
spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
What is the model of this gun?
