Question about Hoover F5906-900 Upright Steam Vacuum
Not dispensing soap; won't pick up moisture.
This is my second Hoover steamvac with problems. When the brushes wouldn't turn, my son found the drive brush shaft broken. Suction and dispensing worked fine until then... now they don't work since the brush problem was solved.
    President:
  • 1,673 Answers
Check the filter on the bottom of the lid for the dirty water tank, make sure it isn't pushed all of the way up, needs at least a gap of 1/4 inch or so. Also make sure that the lid for the tank is locked down and not loose on one end.
Posted on Jan 06, 2008
6ya staff
SOURCE:
Brushes won't turn
The brushes are powered by air suction from the motor. At the heart of this complicated system are roller bearings. When one fails the system fails. This is not one of the parts that Hoover thinks is needed on it's parts site so I've haven't found a way to repair this.
Jun 28, 2011 | Hoover F7452-900 SteamVac Upright Vacuum
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Why don't the brushes go round on my Hoover carpet cleaner
HI There,
Here's a link to a Fixya repair solution that I recently did on this exact problem. It's actually a fairly common problem. The second link is to another solution that will walk you through step by step how to replace the turbine assembly if you find out this is what the problem is.
How to Diagnosis a Hoover steamvac spinscrub brushes stop spinning:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
How to replace the Brush Turbine Gear if you find out this is what has gone bad:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
If you need to purchase a new spinscrub brush block, here's a direct link to the exact brush block that's used in your model:
Hoover SteamVac Brush Block - 5 Brushes Part # 48437022
If you have any follow up questions, please don't hesitate to ask them by using the comment form here on the Fixya repair page.
Thank you,
Chris Jones
GoVacuum.com
May 12, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water will not dispense through the attachment hose and come out of the brush in order to clean stairs
The Dual V has pumps and solenoids that control soap and water flow. This type of problem requires shop service.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jul 19, 2009 | Hoover F7431-900 SteamVac Vacuum
I have a Hoover steamvac Dual V carpet cleaner Model No. F7427-900. This is a spin scrub upright. My brushes will not work. We think the white square that the brushes fit up into in the center of the...
You are on the right track! Place a screwdriver (flatbladed) into the white drive square and try to turn it. If it is locked up the drive assembly is your problem. It is very common for these parts to lock up because of the moisture involved with these machines. The only way to fix this is by replacing the drive unit, simply remove the hood of the machine and you will find 4 screws and one hose hold this drive in place.
If the gear assembly turns just fine you have a problem elsewhere. More than likely it has something to do with the dirty water tank. All the drives and pumps on these run off the suction created in the recovery tank. I would remove the tank take the lid off and then place it all back again. Then attempt to run the machine.
If the tank is on fine, the white gear turns ok and the brushes still will not turn:
Time to go back and inspect that brush block. The drive tab may be brolken off too short, or something else to do with that particular part.
In the case you can find nothing wrong with any of this, i would contact the local hoover warranty service center. A locator is on the hoover website. Hoover picks out the best vacuum dealers to service their product, for a small fee they would probably be able to tell you just what is wrong with it.
Best of Luck!
Jun 09, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac v2
Either you need a new tank, or there is a problem with the platform that the tank sits on. The tank has to sit correctly or it won't work.
Oct 21, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F5906-900 Upright Steam Vacuum Logo
59 people viewed this question
Top Hoover Vacuums Experts
Kirk Thompson
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
