Question about Sony CDP-CX235 200-Disc CD Changer
Won't load cd ,, intermitten
Swings to the general area then acts like ,, not aligned or doesn't know if it's at the right disc
  • 2 more comments
  • Anonymous Feb 25, 2008
    does not pick up disc not aligned properly
  • timp3 Jan 01, 2009
    Well, After most of the guys told me it was one of the carousel photo
    eyes I started taking the thing apart. After cleaning the eyes and
    reassembling the unit it did the same thing. While observing the motion
    of the carousel I noticed that the movement was jerky, not smooth like
    it was originally. I started to look at the drive motor and related
    gearing. I took the belt off and moved the motor and the drive gearing
    independently looking for stiff movement. I found particles in the
    grease , grit sized pieces of white stuff in between the teeth on the
    belt. Cleaned the belt and related gears and belt pulleys and LOW AND
    BEHOLD smooth movement of the carousel and no more loading problem. The
    jerky movement of the carousel did not agree with the locating
    electronics for the carousel. Tim
  • Anonymous Jan 19, 2009
    my cdp cx235 is jammed
    cds fell around on the inside whilst moving
    how can open it up?
  • timp3 Feb 09, 2009
    Well, After most of the guys told me it was one of the carousel photo eyes I started taking the thing apart. After cleaning the eyes and reassembling the unit it did the same thing. While observing the motion of the carousel I noticed that the movement was jerky, not smooth like it was originally. I started to look at the drive motor and related gearing. I took the belt off and moved the motor and the drive gearing independently looking for stiff movement. I found particles in the grease , grit sized pieces of white stuff in between the teeth on the belt. Cleaned the belt and related gears and belt pulleys and LOW AND BEHOLD smooth movement of the carousel and no more loading problem. The jerky movement of the carousel did not agree with the locating electronics for the carousel. Tim
  • 458 Answers
Check all loding belt or replaced part no:
Sony 4-982-867-01 BELT, LOADING MOTOR
Sony 4-962-822-01 BELT, T.T. MOTOR
Sony 4-210-030-01 CD DOOR MOTOR BELT
Posted on Apr 04, 2010
Canon pixma mg5320
Their software is not the only game in town - try some other software
Sep 06, 2017 | Office Equipment & Supplies
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
Won't read d d keeps saying bad disk
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Oct 05, 2011 | Curtis DVD1041 Player
I have a Boggle Interactive disc WINDOWS 95, 99021, made by Hasbro and it will not load on to my new computer. It played ok on my old comp but won't load. In fact the comp. doesn't even act like it...
TRY DISABLING YOUR VIRUS PROTECTION FIRST...THEN INSERT YOUR DISK, GO TO SOFTWARE PROGRAMS, CLICK ON INSTALL NEW SOFTWARE...OR YOU CAN TRY LEAVING YOUR DISK IN AND RESTART YOUR COMPUTER, TO SEE IF IT WILL DETECT YOUR SOFTWARE...MORE THAN LIKELY YOU'LL HAVE TO DISABLE YOUR VIRUS PROTECTION FIRST, UNTILL YOUR ABLE TO INSTALL THE SOFTWARE.
DO NOT HAVE YOUR GAME HOOKED UP, UNTILL SOFTWARE IS INSTALLED.
REBOOT YOUR COMPUTER, WITH GAME HOOKED UP, SO THE COMPUTER CAN DETECT YOUR HARDWARE.
HOPE THIS HELPS!
Aug 31, 2011 | Video Game Consoles & Games
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Aug 16, 2011 | Computers & Internet
Hi i have a bose 321 and when trying to play a movie i get an error message that says cannot read disc. How do i fix?
Your unit has developed a drive problem in most cases. This means either the disc motor or the laser unit is nonfunctional or out of alignment. Not for the faint of heart.
Question: Can you feel or hear the drive motor running during "load" or hear a shuffling or clocking noise? That latter would indicate that the laser is at least looking or the disc.
Question: Will the unit play a CD or accept a cleaning disc? If so, it is generally an alignment problem.
Good luck.
Jun 05, 2011 | Bose 3 2 1 GSX System
Hi, I have a Sony CDP-CA8ES whose turntable acts weird. It seems to be out of sync, gets stuck in the open position, doesn't position discs correctly, etc. Any ideas? Thanks, Ed
hi,
may be ur cd players mechanical alignment have some problem , teeth of loading wheel or teeth in try may be broken. just check the same. if found faulty try to replace it.
ok
Dec 26, 2010 | Sony CDP-CA8ES CD Player
I have a Seiko Westminster Whittingham Clock, which keeps perfect time, but the pendulum won't swing for more than a couple of minutes. Does anyone know what's causing this? Bob
mcdevito75 here, I would figure the pendulum serves 2 purposes, 1 it acts like a seconds hand on a watch and 2 more important it acts a s a counter weight keeping the clock in Balance. It sounds like the Pendulum mechanism needs cleaning and or adjustment, look for a small watch repair shop in your area, they can advise you on a clock repair shop in your area, or you can always check with the repair service directory right here at fixya, bottom of page, click on repair service directory the watches / clocks.
Jul 03, 2010 | Seiko Mantel Clock
TOSHIBA A30 SATELLITE. WON`T BOOT, DOESN`T MATTER WHAT I DO. HAD TRIED RECOVERY CD`S , START FROM NETWORK,FROM PARALLEL...I THINK PRETTY MUCH EVERYTHING...AND NOTHING. RIGHT NOW, AM CLUELESS. THINK IS THE...
Put your Windows disc in the disc drive.
Tap F12 when the computer is starting up.
Select load from disc.
Install Windows.
It seems to be the only solution to your problem.
Hopefully, you made a partition and saved your files onto there, or onto an external hard drive to prevent data loss.
Jul 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Stanton C500 Dual CD Player
hi, check that when the right side tray closes the screen must show up READ or DISC CHECK. the behaviour must be the same as the left side cd deck. if loading is faulty then the cd tray is out of alignment or sensing swithches are faulty. if disc is loading then u have a laser pickup problem or the laser ribbon cable is intermittent or the spindle motor is tired or the laser lens needs accurate cleaning. cheers.
Aug 05, 2007 | Stanton C.500 Dual CD Player
Sony CDP-CX235 200-Disc CD Changer Logo
290 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
