Question about Sanyo PLC-XU47 Multimedia Projector
Projector projects with pink tint
My Sanyo PLC-XU47 Multimedia Projector has developed a problem where the image it projects has a permanent pink tint. This occurs when a computer is attached, but is not present when the projector is displaying its 'idle' screen before a computer is attached. The lamp replace warning light has not come on so it does not appear to be a problem with the lamp bulb. Can anyone please help?
  • 1 more comment
  • Anonymous Feb 25, 2008
    I have a PLC-XU48 and there is blue tint that covers about 1/2 of the screen. When the screen is showing black I can still see an obvious blue tint. I have read that a lamp change may not fix this. Any Ideas?
  • thewebby Jul 10, 2008
    I also have the Sanyo PLC-XU48 and just swapped out three hundred bucks worth of replacement lamp to find this isn't an unknown problem.
  • Anonymous Dec 30, 2008
    I have an Epson Powerlite 745c which shows a pink tint as if the red color had been turned up and the blue and green left down, but when i went to the color adjustments it did not match what i was seeing so there is an obvious problem with either the lamp or the lens's. Does anyone know a solution to this pink tint besides replacing the lamp??? I'd rather not have to go buy a new lamp when the one i have still works. I was able to adjust the color manually so that the pinkish color sort of went away and the blue stood out more, but this still didn't look at full quality as it is supposed to. Any help or suggestions would be great.
    Thanks.
2 Suggested Answers
  • 3 Answers
SOURCE: Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Posted on Feb 08, 2008
When projector is out of focus there are purple blotches on the lcd panels which u can see when projecting a white image, how do i clean this>?
you'll need to use an electronic swab, and use air to blow out the loose dust particles.
http://www.alibaba.com/product-gs/426050499/3_Round_Tip_Foam_Swab.html
May 28, 2011 | Sanyo PLC-XU47 LCD Projector
No focus
lamp isn't striking. either the lamp is blown (check for burn spots or cracks) or the ballast isn't firing the lamp. either way, one of them need replacing.
Aug 04, 2009 | Sanyo PLC-XU47 Multimedia Projector
How do i change a bulb please
Hi - You can download the manual from the link underlined in blue below:
PLC-XU47
See page 48:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 29, 2008 | Sanyo PLC-XU47 Multimedia Projector
I am getting the warning light come on as soon as u turn it on and about 10 seconds later the projector turns off
can be a sensor problem or powerboard failure.Check if the fans are spinning.
Is your lamp life over time?
Jun 15, 2008 | Sanyo PLC-XU47 Multimedia Projector
Sanyo PLC-XU47 seems to power cycle
Welcome to resolve the problem if you please say what are the solution to me the same problem
Jun 07, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC-SW30
The filters are starting to show their age. This is a normal occurance for projectors and is the result of heat. The filters and/or the mirrors might need to be changed.
Dan
May 08, 2008 | Sanyo PLC-SW30 Multimedia Projector
PLC-XW55 KEY LOCK FEATURE
Hi
If you accidentally lock the projector, you need to disconnect the AC power cord. Then HOLD the SELECT button at the same time as reconnecting the AC power cord again.
This should reset the lock out.
Dec 24, 2007 | Sanyo PLC-XU47 Multimedia Projector
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Sanyo Pro Xtrax
You need to change th bulb. It's damaged
Sep 03, 2007 | Sanyo PLC XU35 Multimedia Projector
Tinted image
If you are plugging in a monitor cable, it is most likely a cable issue. I would try another cable and make sure the cable is seated firmly into the projector. If that doesn't help, check the port on the projector for bent or missing pins because it seems that not all of the video information is reaching the unit.
Feb 02, 2007 | Sanyo PLC-XT16 Multimedia Projector
Sanyo PLC-XU47 Multimedia Projector Logo
328 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
k24674
Rob Hill
Rob Hill
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
