Question about BenQ T701 TFT 17" LCD Monitor
Moniter i have an envision moniter. When i turn my computer on the screen stays black and a small box does come on for about 5 seconds and says no signal. whaat do i do to get a picture to come up. I do hear the windows come on but no picture
  • DODOO Mar 02, 2008
    moniter says no signal and nothing else
  • 472 Answers
Vjeck the video cable is connected properly at both ends, to the monitor and to the video card.
If your video card has 2 monitor connectors, then move the video cable to the second one. It sounds like your monitor is not reciceving the correct signals.
If your computer has onboard video (blue port on the back where the silver panel is) then try connecting the video cable to that instead. If you also have an internal video card, then it may not be working so the video is being sent through there instead.
Post back if you have further problems or if this does not resolve the problem.
Posted on Apr 21, 2008
  • 180 Answers
Check the inverter board.
WHY IS THE GREEEN POWER BUTTON FLASHING ON MY MONITER AND THE SCREEN THEN GOWS BLACK
When the power light is flashing the monitor is not getting a stable signal. This is hard to answer without direct troubleshooting. Check the cables first, make sure they are connected securely. If you still have problems test another monitor you know works or move monitor to a computer you know works, this will determine if the monitor is the problem or not and tell you if it is your "graphics port or adapter". If another monitor works fine, use the working cables to test the "broken" monitor. If you have an "all-in-one" computer, ignore the above steps and use a start-up repair disk. The reason this is hard to troubleshoot is there are so many things to diagnose. More than likely your "graphics card" is failing. These are some tricks to repair. You can update the driver, buy a graphic card separate from the stock port.
May 21, 2016 | Dell E172FP 17" LCD Flat Panel Monitor
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Hi My name is denise, I have the invision 22" Moniter can you tell me are there build in speakers on the moniter.
http://www.testfreaks.com/blog/review/22-envision-g22lwk-dvi-widescreen-lcd-monitor-wspeakers-black/
Here is a review of the monitor, it says it does have speakers, but not very good review, but most if not all speakers that are built in are not great. I hope this helped, Gym
Dec 21, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
My Acer LCD AL1711 went off after seconds of turning on.
This monitor has "back lights" that are essentially like flourescent lights. These are high voltage lights and can easily fail. since you are getting some light initially, I would suspect a defective part that heats up a bit right away and then fails. I would try to replace the entire backlight board. This is the small board on the side (usually).
Dan
Mar 27, 2008 | Acer AL1711BM (Black) 17" LCD Monitor
Black outs
May be your IP board is going out. Replace IP board.
Aug 25, 2007 | Acer AL1916W 19" LCD Monitor
BenQ T701 TFT 17" LCD Monitor Logo
552 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
