Question about AOpen (MX4SGI4DN2PRE) Motherboard
Manual i need a manual for a mx4bs...not sure where the jumpers go for the reset and power for the front panel switches...any help would be greatly appriciated...ty
  • 91 Answers
Ftp://ftp.aopen.com/pub/manual/mb/mx4bs/mx4bs-ol-e.pdf here is the manual that you needs i found it on the www.aopen.com website it says for the front panel switches attach the power led,empi,speakers,power and reset switch connectors to corresponding pins. If you enable suspend mode item in bios setup the acpi and power led will keep flashing while the system is in suspend mode locate the power switch cable from your atx housing. It is a 2 pin female connector from the housing front panel. Plug this connector to the soft connector marked spwr there is a diagram to show you how to hook it up if you need anymore hesitate plz give me a shout and i willl be able to assist you more
Posted on Sep 10, 2007
SOURCE:
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
I have mercury mother board and its having nine pinsocket for reset switch,power switch,hd led ,etc but i dont know their proper connections. there are some nos besides but not understandable . can you...
Hi Rajen samani!
Most mercury motherboards with a nine pin front panel connection use the following configuration.
You may want to double check to make sure that your motherboard follows this configuration. Just go to http://www.mercury-pc.com/downloads.php, enter your model number, and you'll be able to download the manual for your board. The jumper configuration should be in a section labeled "Front Panel Connection" or something similar.
Hope that Helps!
Mar 07, 2011 | Mercury Computers & Internet
Dear sir...greetings... i have a ibm fw82801db motherboard which is working fine... the main problem what i am facing is i have a 20 pin front panel jack like FDD jack as unable to connect my front...
Because of the many configuration of motherboard, I can possibly know how to help you with this problem without the keyboard in front of me. The best advice to you is to go back to the manual to find the proper connection of those jumpers.
Feb 26, 2011 | Intel Desktop Board D845HV Motherboard
Unable to find the power switch to connect to
If you no longer have the manual for you're Intel D815EEA motherboard, open the link provided and download it; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17793&ProdId=385&lang=eng
You will also need Adobe reader installed to view the manual; http://www.adobe.com/products/reader/
Read over pages 65 to 68.
Once completed turn to page 68 Figure 23. Front Panel connectors. Figure 23 shows two views.
View - (left figure), shows J9C1 as you look down at the front panel pins. The right figure will not be needed. Connect each jumper or each pair as shown.
Wire colors are important and do vary from case to case. The common color of each pair will most likely be used for negative. Wire colors such as blue, light blue, green, light green, red and light red are commonly used as positive.
Pin 1 will be positive and pin 3 will be negative. This is letter - C. Hard drive activity LED.
Pin 2 is positive and pin 4 is negative. Case power LED, and so forth.
As mentioned on page 65, the case front panel pins use 5 volts DC. If you make a mistake and place a jumper backwards (No LED light), just power off the switch on the back of the power supply and correct the jumper by turning it 180 deg. If you’re case’s LEDs do not light up than you will need to connect letter G and letter H. The electronic circuits under the motherboard should supply all 16 motherboard pins with the 5 volt DC and ground needed.
Cheers'
Mike
Feb 28, 2010 | Zerus Intel Desktop Board D815EEA...
How do i connect the casing power to the motherboard
Open ECS web site and download the manual for your MB, P4VMM2 V7.3; http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=333&CategoryID=1&DetailName=Manual&MenuID=1&LanID=9
You will need Adobe reader to view the manual if you currently do not have it. Download and install Adobe; http://www.adobe.com/products/reader/ With Adobe you can zoom in and out to assist you in connecting your case to the motherboard. Start with page 9. Page 12 and 13 shows you how to connect your case LEDs to the motherboard. Pin 1 is positive for your HDD_LED. Pin 3 is negative for the HDD_LED. ECT. Most wires coming from the case are inserted into a jumper and most jumpers are marked. Ex: HDD for hard disk drive, RS for Reset Switch, PW for power on/off switch ECT.
The case wire colors do vary from case to case. The wire colors blue, light blue, green, light green and red are most common to be positive. The colors white and black are common for negative. Below is a picture of a typical front panel case to motherboard hook up. Less the white standoff jumper block.
Your board uses an internal speaker. Connect the red wire to pin 1 and connect the black wire to pin 4. See page 11 for location and page 12 for connection.
Use the manual. Its a great guide.
Happy holidays!
Mike
Dec 19, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Green light comes on but wont power on
Remove the battery. Try again. If the PC starts, change the battery.
Nov 05, 2009 | ASUS P4B266 Motherboard
Can't Fix FRONT PANEL HEADER on my Motherboard
Here is a link to your motherboard manual:
D845PEBT2 Manual
Go to Page 33 for the Front Panel connections...with pictures. :-)
Thanks for using Fixya.
Jun 12, 2009 | Intel Desktop Board D845PEBT2 Motherboard
POWER SWITCH
Hi sivaprasanna,
Do you still have your manual? If so turn to page 72 for location.
For a close look at the motherboard front panel led to MB pins look at these two pics.
Location of front panel connections;
Item " A " is the front panel MB pins.
Pic two is the layout for each front panel connection;
The power on jumper uses pins 7 & 8.
Pin 7 is positive & pin 8 is negative.
Good luck sivaprasanna!
Mike
Nov 09, 2008 | Intel D850MV Motherboard
Jumpers
Generally you don't need to know jumper settings in newer motherboards. What you may be referring to is the front panel i/o connector. This has the power switch, reset switch, power LED, hdd LED, and etc.
To download the motherboard manual, please go to http://download.aopen.com.tw/userdownload_List.aspx?RecNo=6027&Model=435
Hope this helps!
Oct 18, 2008 | AOpen MK79G-N (91.8B110.101) Motherboard
T2893 Motherboard Layout - Where do the power jumpers go?
go to this link for the information you need http://www.intel.com/design/motherbd/sr/sr_con.htm#IC
May 05, 2007 | E-Machines T2893 PC Desktop
AOpen (MX4SGI4DN2PRE) Motherboard Logo
711 people viewed this question
Top AOpen Computers & Internet Experts
Ekse
Alun Cox
Joaquim Martins
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
