Question about Panasonic PV-GS150 Mini DV Digital Camcorder
Damage to camera
I've never had any problem with my PV-GS150 -- until this weekend when my tent blew over in the wind, tore and spilled about a liter of sand on the camera which was "safely" stashed inside. Now it's all haywire because of the sand infiltration. Should I consider this a complete loss or are there people who can clean it out and get it functioning as good as new. This is important because I rely on this for my freelance writing and photography business.
    Champion:
  • 217 Answers
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 18, 2007
SOURCE:
This is a PV-GS150, hopefully it similar. Dropped, no obvious external damage, won't turn on, battery OK, recharged externally. Slide switch moves from off to no, no lights come on, no life anywhere,...
The possibilities are literally endless. It could be anything from a bad switch, to a loose wire, to a blown fuse, to a blown board. Without some pretty sophisticated tools, some spare parts, and an in depth knowledge of the unit, it's not going to be fixed. If you like the cam enough, take it to a qualified repair center. If not, junk it and get something else.
Jul 06, 2011 | Panasonic PV-GS300 Mini DV Digital...
Push the reset button
you take it to service center. there are chances that you will mess it up more than than what is it now
Jan 28, 2008 | Panasonic PV-GS150 Mini DV Digital...
My pv-gs150 will not power up
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 15, 2010 | Panasonic PV-GS150 Mini DV Digital...
My Panasonic PV-GS150 is having an autofocus problem. It will be focused on a target and then will go out of focus and then come back in to focus. It does this repeatably. It used to stay focused on the...
The solution is never buy a Panasonic DV camera. Tons of users complain of focus failure and Panasonic pretends the problem does not exist. Great cameras otherwise but out of focus does not cut it.
PV GS250 $1000 brick
Dec 08, 2009 | Panasonic Video Cameras
I am unable to connect my Panasonic PV GS150 handycam and Vista business edition running laptop using a USB cable. Do I need driver S/W?
You will need to install the USB driver from your software(disc) to your vista.
and make sure the computer is recognizing your camera, check under control panel and device managers list if your product is listed under imaging devices, but chances are you might be having compatibility issues since it doesnt have an updater for Vista, hope this help. pls dont forget to rate. Thanks!!
Apr 09, 2008 | Panasonic PV-GS150 Mini DV Digital...
let the camera sit alone for About 20 min,so that the camcorder automatically turned off. I turned it off, then back on and did not receive the reset button prompt.
if that doesn't work unplug the battery and all power and plug back in.
Panasonic pv-gs150 mac connection
For Macintosh
OS:
Mac OS X v 10.1–X v 10.3
CPU:
iMac, iBook or Power Book G4, Power Mac G4 or
Power Mac G5
RAM:
64 MB or more
≥The USB equipment operates with the driver
installed as standard in OS.
Sep 30, 2007 | Panasonic PV-GS150 Mini DV Digital...
Panasonic PV-GS150 wont eject
Sep 17, 2007 | Panasonic PV-GS150 Mini DV Digital...
HELP-AUDIO not playing out of Headphones/External Speakers!!
lower the volume on the camera by using the tight/wide slider on the cam
Oct 11, 2006 | Panasonic PV-GS150 Mini DV Digital...
Panasonic PV-GS150 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
