Question about Bosch 23 in. SHU5302UC Built-in Dishwasher
2 hour run time
It will run for 2 hours or more could it be the board.?
  • Pat Fleury Mar 27, 2008
    My Bosch SHU5302UC has operated flawlessly for years. Now, it says run time is "2H", but after 35 minutes the water has not heated and nothing else is happening. We suspect a part has failed, but is it the heater or the control board--any thoughts on this?
  • 909 Answers
One needs to take into concideration how long it takes for the water to enter the unit and how long it takes for the water to heat up.these factors will influence the running time. defective heater very common.
Posted on Oct 08, 2007
SOURCE:
Dishwasher takes 3 hours to run through programme
3 hours isn't "extremely" long. If you run a normal cycle, it should run about 2-2:30 hours normally with the drying cycle. Now if it's over 3 hours, that would be a problem. Make sure that when you open the door that there is a lot of steam coming out, because that is the only thing that can extend the cycle is if the dishwasher isn't heating the water. Unfortunately this is a very common issue and it means that your control board inside the door has failed. There is a relay on the board that shorts out. This relay sends power to the heater, so when it fails the dishwasher doesn't wash well and it will run forever trying to heat the water which will never happen.
Sep 10, 2013 | Bosch Dishwashers
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
Tempus fugit westminster mantle battery operated clock has 2 buttons under an H and 2 buttons under an M. how do I set the chimes? Amy Howard
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
Feb 08, 2010 | Seiko Mantel Clock
My dishwasher takes 2 1/2 hours to run. Is this normal?
Smart wash: 2 hours Anti-bacterial wash: 2.5 hours Normal wash: 2 hours China/Gentle: 1.5 hours Quick Rinse: 10 minutes
Note: If water temperature is low the times shown above will be extended to allow for water heating time.
This information is from page 14 of the manual.
Jan 16, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
1990 454 mercruiser misfire under load when warmed up
Running on a stand is not the same as running under power...In the water, you are essentially running on a dynomometer (dyno is a big water brake) If you can prove that the module isn't putting in enough advance, it would be doing the same thing that I mentioned with the damper, only for a different reason. So...you're likely on the right track. (rather have a points setup out on the water...anything goes wrong, you fix it without a tow!!!!)
Good luck
Aug 29, 2009 | 1988 Chevrolet Suburban
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
I have a micathermic 2000w heater. Whats the running costs associated.
Depending on the utility rates in your area, mine are 10 cents per kilowatt/hr. assuming 10 cents, to run a 2000 watt heater for one hour, that is 2 kilowatts in an hour, or 20 cents per hour. That's if it runs continuous for the whole hour, which it won't. It will cycle. Maybe on half the time...so about 10 0r 12 cents an hour
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 03, 2009 | Sunbeam 738-400 Heater
How much time laptop should normally run on fully charged battery in good condition
This varies from laptop to laptop, when new a it should not run less than one hour (that is with heavy use), I have seen some brands run as long as 3 hours (top end models)
Jul 01, 2008 | Computers & Internet
System Hanging at any time
Dear Ramesh,
Have you ever change/update your RAM in recent time?
Mar 14, 2008 | Intel D845GVSR Motherboard
Obtaining actual sewing and embroidery hours on machine
To find out the running time of your Des. 1 machine; Switch on machine touch 'SET' on the screen then press ' More' 3 times and you will see' Running time' hours and minutes.
Nov 28, 2007 | Husqvarna Designer I
Bosch 23 in. SHU5302UC Built-in Dishwasher Logo
312 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
