Question about Philips GoGear HDD060 MP3 Player
Philips Gogear HDD6330 AC adaptor / Sync cable
I have lost the AC adaptor / sync cable for my Gogear HDD6330. Does anyone know the 30 pin connector configuration so that I can modified my Ipod cable for it. Thanks.
I know its not the answer that you really want, but these power supply/usb units do come up for sale on ebay quit often.
Posted on Jan 03, 2008
SOURCE:
USB port for iphone sync
The iPhone will sync to iTunes on a computer. If the display has a USB port, there must be another USB cord to the computer. The iPhone will go through it to get to the computer.
Apr 15, 2014 | Atlona ATNO-AT13033-2 - AT13033-2 6FT Mini...
Philips GoGear HDD6330 MP3 Player will not sync music files onto it? How do I fix that and has deleted all previous ones! Please help>
This could be the player's connection mode in combination with your synchronization software. If you are using Windows Media Player or Philips Songbird to sync, the player will need to be set for MTP connection mode. Most other software that works with regular flash drives will need the player set for MSC connection mode. Whatever you are using, simply try the other mode.
To change the connection mode, select "PC connection preference" in the Settings menu of the player.
If you found this information helpful, please indicate as such.
Apr 12, 2010 | Philips GoGear HDD6330 MP3 Player
It wont charge or sync to my computer
try reinstalling the software...this time with the player connected to the pc while the program is being installed
May 15, 2009 | Philips GoGear HDD6330 MP3 Player
I cannot sync any songs to Philips GoGear HDD6330/17 from windows vista why does this happen?
my philips gogear 30 gb won't sink it keeps saying connect to computer, even though i do. HHHHHHHHHHEEELLP
Mar 11, 2009 | Philips GoGear HDD6330 MP3 Player
Lost software for my Phillips GoGear
The Philips site offers the software you need.
If you have the Musicmatch player or windows media player 10
you should be able to download from either player
Sep 01, 2008 | Philips GoGear HDD6330 MP3 Player
Here is the URL for you player..
http://www.consumer.philips.com/consumer/en/us/consumer/cc/_language_us/_productid_SA3015_37_US_CONSUMER
For Drivers/software/firmware please go to this url
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=MP3_PLAYERS_CA&sct=SU00304_SU&session=20080318191444_24.109.69.159&grp=PORTABLE_ENTERTAINMENT_GR&ctn=SA3015/37&mid=Link_Software&hlt=Link_Software
Mar 18, 2008 | Philips GoGear HDD6330 MP3 Player
Philips mp3 player
whenever i turn on my philips 1gb gogear it says player problem connect to pc.
Feb 01, 2008 | Philips GoGear HDD6330 MP3 Player
How do i put pics on my 30GB gogear hdd6330
You will be able to transfer songs using Windows Media Player after this -
Turn off automatic synchronization first.
When you first synced your player to Windows Media Player, you may have set up the automatic sync option. When this option is selected, Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the player. Now, every time you sync you device, it adds every new file from your computer into the player automatically. It will even delete songs from your player that were on there before.
Go into Windows Media Player 11 with your player connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portable media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding/deleting songs/files you don't want into your player.
Then:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Nov 04, 2007 | Philips GoGear HDD6330 MP3 Player
WMA doesn't detect my Philips GoGear HDD6330 MP3 Player
I have an HDD6330 and instead of using WMP, because it has so many issues, I use Rhapsody free player. It works great, syncs immediately with no issues. It also has easy file transferability.
Sep 12, 2007 | Philips GoGear HDD6330 MP3 Player
How do i put photos on?
There is a folder that can be seen in Explorer. For example:
My Computer\Philips HDD63XX GoGear\Media\Pictures
But transferring files this way is futile. There's something about the media player 10 sync process that updates a database on the mp3 player. Media Player 11 doesn't seem to do this correctly. Philips needs to resolve this as new machines are not shipping with version 10 anymore.
Aug 27, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GoGear HDD060 MP3 Player Logo
144 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
