FixYa.com
Tags:
RCA R52WM24 52 in. HDTV Television
Image size too large, cannot see all of sports...
posted by violentce on Sep 10, 2007
I've noticed this and it is a little irritating, since I am using Component Cables from my cable box I do not get all of the size adjusting features from the TV's built in menu's.
So when watching ESPN for instance, when they scroll scores accross the bottom the ESPN logo, and team names are partially cut off. The screen is oversized proportionally around the entire screen, the problem is just noticed alot more on news and sports stations. Is there some "fine tuning" features inside the TV that me as a consumer are not supposed to be able to access?
I have a 4 yr. onsite agreement with this TV, is this something that the service provider will do?
Comment by violentce, posted on Sep 10, 2007
I have shuffled through all of the settings of my box (it is a Scientific Atlantic Explorer 8300HD) and if is set to an output format of 1080i and the aspect ratio of 16:9 with stretch 4:3 picture. There doesn't appear to be any finetuning that lets me shrink the screen by 20 or 30 pixel to fit perfectly. I guess that is all that is needed to be adjusted.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 06, 2008
FixYa! (100)
skier1080
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
hey voiolentce. if you press the # button on the cablebox remote control you can fine tune the zoom by those 20 pixels you want. you are most likely set at zoom 1 currently. thats where i was when i had this same problem and it took me days to figure out that all i needed to do was press the damn # button. i couldnt see any of the scores on espn sports games and its been driving me crazy. hope this helps!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Thanks for Trying (70)
Leadtech
Rank:Guru Guru
Rating: 88%, 343 votes
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Rating Locked! (?) violentce has rated this solution as Thanks for Trying
Solution #3
posted on Mar 08, 2008
Not Rated (0)
dmichie
Rank:Wiz Wiz
Rating: 83%, 32 votes
1080i is too high, bump it down a bit.
Can you Help with these Projection Televisions problems?
the colors on tv are off.
I can't figure out which one is... Answer This...
RCA R52WH74 convergence problem
Hey, I got a RCA R52WH74 and ... Answer This...
distorted picture on RCA LCD TV
the picture is curved and... Answer This...
No Green in tv picture
I have a RCA R52WM24 tv and the... Answer This...
Rca R52wm24
My tv plays fine then all of a... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
