Question about Roper RAS8445KQ Top Load Washer
Washer wont fill, keeps draining - Roper RAS8445KQ Top Load Washer
  • docflash Sep 10, 2007
    No all l;isted isses have been checked and there is no air tight seal, washer has been working for 3 years just fine, seems to happen more when switching water level , after switching to high spin and letting it complete high spin then back to wash cycle it seems ok, as long as water level is not changed, it is as if the drain stays open at all times when it happens
  • dmartin9250 Feb 13, 2009
    I have a crosley machine about 8 years old. The tub will fill up then it drains out and this is repeated over and over on the wash and rinse cycle.
  • 5,911 Answers
If you do not allow an air gap for proper drainage on your drain line, the water will siphon out of the washer as it tries to fill. Double check to make sure: 1. You do not have the washer drain hose placed too far down into the standpipe. 2. You do not have the top of the standpipe sealed off. Placing the hose too far into the standpipe may cause the drain line to be sitting in water in the drain trap, leaving no air gap. Sealing off the top of the standpipe will have the same affect. Remember, you need an air gap for proper drainage. Only place the hose about 3 to 4 inches into the standpipe and the fit should not be tight. That is, there should be an air gap around the drain hose as it sits inside the standpipe. Double check and let me know if this helps.
Posted on Sep 10, 2007
My washing machine keeps filling with water
If the washer keeps filling up without overflowing onto the floor , then you have the drain hose too deep into the drain and it is siphoning, pull the drain hose back up from being so deep and have it only about 10 inches into the drain, tie it into place with a shoestring or wire tie.
Now if your problem is that the washer is overflowing onto the floor, then there is a clear rubber hose that has been disconnected from the washer, this is the diaphragm hose. Have a technician reattach it. It shuts the water off and starts the machine when its gets enough water, but it wont if the hose is disconnected. Mr Burk
Feb 15, 2015 | Washing Machines
Washing machine keeps filling and draining at the same time and wont fill enough to move on to the next cycle
The drain hose is too low and the water just runs right out...The highest point of the drain hose needs to be higher then the top of the washer before it goes back down into the drain. Also if the hose is sticking into water it can create a siphon which pulls the water out of the washer... make sure that you also have an air gap...
Heatman101
Mar 10, 2010 | Frigidaire FGX831C Top Load Stacked Washer...
I have a kenmore model 110 top loading washing machine that keeps draining and wont fill up but sometimes it does and sometimes it does not. Help!
Your drain hose is too far down into the pipe behind the washer. What's happening is your drain hose is actually siphoning water from th washer the same time its trying to fill up. Pull the drain hose up from the drain pipe and secure it so its doesnt fly out when the washer is draining. Check too see if the problem goes away. If not pull the drain hose out more repeat steps.
Feb 17, 2010 | Washing Machines
Trying to drain and fill at same time wont switch off
pull the drain hose up out off the stand pipe until only a few inches of hose are into the drain. you are siphoning. happens all the time
May 25, 2009 | GE WBSR3140DW Top Load Washer
Washer wont fill up, keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire wont fill,just keeps draining
Your drain hose must be 36 inches from the ground. Any lower and the water siphons out.
Apr 20, 2009 | Frigidaire Washing Machines
Water keeps filling the washer
If the washer keeps filling and overfilling then unplug the machine and see if the water still continues to come in. If this is the case, you have a bad water valve. If the washer just keeps filling and never gets to the top then your drain hose is shoved too far down into your house standpipe and must be pulled up and an air gap established.PART NUMBER 285805 @ 30.00 FOR WATER VALVE
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag legacy series tub wont fill
Your drain hose is too low or there is no air gap where the hose enters the drain line.
This causes the water to siphon out as it fills.
Mar 08, 2009 | Maytag Legacy Series Top Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Washer keeps draining
Sounds like you may have a siphoning problem. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Double check your installation and drain hose placement. You need to ensure you have an air gap to break the suction caused by the drain line. In the event that this is not a simple siphoning issue, please let me know if you require additional assistance. I hope this helps you.
Oct 29, 2008 | Frigidaire FWS833A Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
251 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
