Question about SMC Barricade g SMC2804WBRP-G Wireless Router
Wireless Our computers are connecting to the wireless router, but the router is not connecting to the internet(and yes, we plugged in the cable). When we connect computer directly to modem(with the same cable) there are no problems. Have not changed any settings, it just suddenly quit connecting.
  • 59 Answers
Router is probably configured incorrectly. Try this... Turn off cable modem and router for 1 min. Turn on cable modem...when done booting..turn on router...check for internet. If no...log into router and make sure it is NOT in PPOE but rather in dynamic mode. Good lUck
Posted on Sep 10, 2007
4 Suggested Answers
SOURCE:
  • 77 Answers
SOURCE: Can't connect via my wireless router to the internet - but my cable modem is fine!
Hi!
Do you know how to check the IP address of your computer?
Maybe you need to reconfigure the router.
Posted on May 05, 2008
jerryg50
  • 1691 Answers
SOURCE: wrt54g router simply quit working on the base
The simplist solution is to try a full reset. There should be a recessed reset button on either the front or rear of the unit. While the power is on, press the reset button for about 10 seconds, and then release. The unit should re-set.
Then you will have to access the router via your browser to re-setup the parameters.
For details about re-setting the unit, and doing the setup refer to the user manual.
If the reset process does not work, there is a strong possiblity that the router is defective. It will be cheaper to buy a new router than sending it in for service if it is out of warranty.
Jerry G.
Posted on May 15, 2009
  • 34 Answers
SOURCE: Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Posted on Jan 06, 2010
Dear Sir, There is no provision of fixing my laptop to a wireless router.Can anybody advise how to convert this "laptop" to enable getting wireless connection of internet?
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Jul 29, 2011 | Dell Inspiron 5100 Laptop
When i unplug the cable from my computer i loose internet connection
Unless your computer also has an active & configured wireless adapter, then disconnecting the Ethernet cable between the computer and the router _will_ cause a loss of Internet connectivity.
Jan 10, 2011 | Belkin Basic Wireless Router
My router connected to my computer says limited or no connectivity and says cannot establish a internet connection when the internet is working fine
may be it's showing limited or no connectivity on your wireless connection where it's trying to connect or may be it's connected wirelessly but your wired connection is not communicating properly with router's switch, could be due to bad port on router or bad NIC or bad cable...check in your network connection.
Jul 04, 2010 | Linksys Wireless-N WRT150N Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Can both a computer without wireless netcard also be connected to a wireless modem by cable at the same time as another computer is connected using the wireless settings?
Yes, the wireless router can connect several wireless connected computer at the same time as well as computers using a network cable depending the maximum number LAN ports available on the wireless router.
Jan 26, 2010 | Computers & Internet
Jan 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Will the WBR-2310 work with my wireless internet service. I don't have DSL or Cable or Satellite. I have a wireless service from a local provider.
YES but you need a computer which will bypass your internet service from computer to router and then any wireless computer or any WAN enable device will access internet.
Share your wireless internet to Ethernet and connect with cable to router. WAN is now working.
But remember to configure your WLAN Router.
Regards;
Hasan
Dec 25, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
When one computer is on the internet, the other
Yes You have to buy a minimum of a 4 port router wireless is best.
Oct 15, 2009 | D-Link DIR-615 Wireless Router
SMC Barricade g SMC2804WBRP-G Wireless Router Logo
268 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Jeffrey Groves
Jeffrey Groves
Kris
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
