Question about Sony KP-57HW40 57" Rear Projection Television
Front panel timer/stand by blinking light
I recently fixed the blue arc line problem after moving my tv it worked but ever since my stand by light blinks 3 times every 5-7 sec. did i do something wrong or can i fix this problem
Did you clear the code by hitting display channel 5 volume up then power then press 8 enter or look at sony blinking codes to reset to factory settings
Posted on Jan 30, 2008
SOURCE:
Sony Trinitron Stand By/timer light continous blinking - cannot get picture to come on or how do I turn off the stand by/timer off so the TV picture can come on
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Jun 15, 2017 | Sony FD Trinitron WEGA KV-32FS210 32" TV
Sony KDL-40Z4100 standby light solid red, orange blinks every 4 sec, What part may have gone bad?
The red stand by indicates the set is in PC stand by the blinking orange timer is indicating the timer has been set or has an issue
Mar 13, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
I have a Sony kp53xbr35 rp tv, shutting off
If you know that the convegance IC are bad then I would replaece them frist and see if that will fix the whole problem, it just might. Here is a sight you can go to that may help you if that does not fix it www.somelifeblog.com has some good info on sony not your model but could be same problem. check it out and see.
Nov 16, 2009 | Sony Televison & Video
Sony TV KP-51HW40 solid red lights [timer/standby+stereo]
if the main board by chance got wet you will need to use a blow drier to try and dry it out..it may already be beyond fixing if water goi into it
Aug 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue Screen and TV shuts off
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Jul 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Picture Darker When Changing Channels Sony KP-57WV700
I've had the arcing horizontal lines from time to time in all three colors (differing occasions). I dunno the correct lingo for this stuff, but having the same TV and fixing it myself here goes. It helps to have another set of hands while doing this. Also, eventually you will need to work in the dark so have a small flashlight handy. Put your tv on an unused input so you always have a "dark" background.
Open up the front panel of the TV.... There are phillips head screws running down both sides around the back side of the panel. After removing the screws and the little side panels they screw into, the whole bottom half of the TV can be popped off. Be careful not to pull it off to far as there is wiring running to the front panel controls. (you can disconnect the wiring plugs if you need the panel out of your way, just remember where and which way they go.) Behind the main silver panel is a smaller panel made of a thin pressboard type material. Remove this panel as well. Inside this second panel you will find 3 little knoblike controls (that also have a screwdriver head) that control the "color drive" of the corrosponding guns. They have a little strip of locktite on them to keep them from moving but it dosent hold on to hard. I'm telling you all this from memory and I'm sure the real techs out there head's are about to explode due to my cavalier attitude toward all this. I wish I could tell you exactly which one is the blue but i've adjusted them all at one time of another and can't remember which one is which.
Pick your favorite knob and SLOWLY adjust it to the right. Just a little bit....too much and your TV will pop off and you'll think you've blown up your tv. (I did this once, and had to uplug the tv and let it sit for a little bit before it came back to life, I probably got real lucky on that one)
Now...as you SLOWLY turn this knob, one of two things will happen. one.....another color arc is going to appear on your tv...this tells you you've got the wrong knob. turn it back to where it was. two....your blue arcs will brighten... thats the one you want. Kill the lights in the room...the darker the room the better. Turn the knob down (to the left) until the point at which the arcs disappear, if you go too far, that color will be "underdriven" so you want to hit it just right. It helps to have someone at the back of the room to better observe the arcs, it can be hard to do this sitting as close as you have to be to adjust the magic knobs.
Repeat if you have any green or red arcs.
Use some locktite on the knobs when you have them where you want them, i've used nail polish if I didn't have locktite available.
Rebuild your tv.
Dec 28, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
KP-57HW40 w/ 8 Blinks
8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
Dec 23, 2007 | Sony KP-57HW40 57" Rear Projection...
No picture blinking stand by light
I hve worked on a number of these units , your description is typical of a shorted blue picture tube. The protection circuits in the tv detect that there is a problem thus shutting the unit down to prevent further damage. Sony had a bad run of picture tubes in this series. The replacement cost of the tube is about $250 plus labor. My estimate would be for the repair about $400-500 depending on where you live and how honest your local technican is. I will caution you however, that you could replace this tube and the red or green could go. These would not be covered by the technicians warranty. When these sets are working, they have a superb picture and it is easy to get lured into fixing them. Scrivitron
Jun 13, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
