Question about Rockford Fosgate RFX-8340 CD Player
I want to find and instuction manually for it
I bought a 1999 saturn sc2 and it had this radio in it. I want to hook up a cd changer to it and what to know how it is done.
  • 752 Answers
You either have to buy a Rockford CD changer and it will directly connect, or buy any FM modulated one that you'd like. As for installation, it depends on which brand you go with.
Posted on Sep 10, 2007
  • Mitch
    Mitch Sep 11, 2007
    Have you decided which method you are going to persue?
SOURCE:
1999 saturn sc2 turn signal flasher not working
You likely need to replace the flasher. They fail.
To see what one looks like, enter "e-bay" into your search engine and write "99 Saturn SC2 turn signal flasher" in the box, and you will see them. I just did.
I do not remember whether these plug in under the dashboard, but I think they do.
If not , they would be in the black plastic box of fuses and relays under the hood (in the front of your car).
Both my brother and my sister have one of these cars.
God bless your efforts.
Nov 07, 2016 | Saturn 1999 SC2 Base
After battery replaced I need instuctions to restart radio on 1999 Mercedes C280 , I have code 4 digits
If you have the code, enter it using the numbers and then press Seek or Scan when finished.
Apr 01, 2016 | OEM 1999 Mercedes C230 Radio / CD Player...
How do u set the clock radio in a 93 Saturn sc2
The radio must be turned off to set the clock. Then push the small set button and go up or down with the radio search buttons.
Jan 13, 2011 | 1993 Saturn SC2
1999 SATURN SC2 I changed the battery in my car and now have a radio lock out. Radio reads LOC. Please provide a code. Finest Regards, Helen.
Ms Helen, Sorry, but you are going to have to take proof of car ownership and a picture ID (Drivers license) and go to a GM dealer to get the code. Some radio/TV repair shops might can get it for you but I don't know where your at. For sure a GM dealer can get it. Thank you
Sep 07, 2010 | 1999 Saturn SC
I hooked up my Sony cdx m-600, all works fine but radio does not work. at all. Why?
make sure the unit is hooked to the antenna correctly. This unit will not play the radio and will disable the static noise on the radio. So ensure the antenna is properly hooked in. For more info on how to use the deck click here for the manual. got this directly off sony's website for model cdx m-600. So let me know if that it is properly hooked up and we can figure out where to go from there.
Aug 31, 2010 | Sony CDX-M600 CD Changer
1999 sc2 wiring schematics
wiring schematics can't be copied and uploaded to fixya.com in my experience, unfortunately.
The memory required apparently is not available and there are copyright issues.
I think that your best bet is to buy a paper manual like Haynes or Chilton or the Manufacturer's manual to get detailed schematics for your Saturn SC.
Aug 24, 2010 | 1999 Saturn SC
When i turn on my technics cd player model number sl-mc409 it comes accross the screen f-26 and won't do anything. what does f-26 mean
I've just bought a used changer, that shows the same error. The instuction says " unplug the changer from its outlet, replug it in an turn the changer ON again"
That doesn't help in my case.
Have you found a solution?
May 01, 2010 | Technics SL-MC400 110-Disc CD Changer
Which cd changer is compatable with the mdx-ca580?
all are compatabel CD changers have only three (3) wires to hook up they work with any radio weather it is factory or aftermarket
Apr 28, 2009 | Sony MDX-CA580 MiniDisc Player
Saturn SC1 SC2 1995-1999 Radio Wire/Wiring diagram
For the 1995 SC2:
http://www.modifiedlife.com/1995-saturn-sc2-car-radio-wire-diagram/
Other links on the left side of that page.
HTH.
Mar 08, 2009 | 1995 Saturn Sc
Rockford Fosgate RFX-8340 CD Player Logo
119 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
