Question about GE XL1800 1100 Watts Microwave Oven
Loss od power
The microwave lost power at the end of a 10 minute cooking cycle. The house power circuit is good but there is no power to the unit( Fan, Light. Clock. or microwave)
  • GE Master
  • 9,174 Answers
If you're getting power at the outlet, the most common problems causing a "dead" condition are a bad thermostat (or thermal cutout / thermal fuse) on or near the magnetron, a blown internal fuse, or a problerm on the control circuit board. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If it seems to be a problem on your control board, we repair these for $39.95 nationwide in most cases. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 28, 2007
SOURCE:
Why has my frigidaire microwave (model PLEB30M9ECE) stopped beeping. It still cooks but no longer beeps
Good Afternoon Friend,
I understand that your Frigidaire microwave, model# PLEB30M9ECE, is cooking, but has stopped beeping. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try any cooking cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Microwave Ovens
Emerson Microwave MW8115SS --
I would suggest you check the door switches inside the microwave oven just below the keypad, rectangular in shape. The switches are normally open or closed, set meter to ohms, unhook lead from one side and test with door open and closed. If readings are the same both ways the switch is defective. "check all switches"
Mar 19, 2012 | Emerson Fans Emerson MW8115SS Microwave...
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
The power cuts off after 2 minutes of cooking. The microwave doesnt turn back on for ten minutes.
There is an automatic circuit breaker that it tripping. One of two options
1) Something in your oven is either malfunctioning (difficult to find and replace). It is likely better to just replace than pay to have it fixed.
2) The house circuit that you are using is not providing enough power to the microwave. Check if something else is connected on the same circuit. A microwave runs poorly when not getting the full 115 volts that it was designed for and may fall into a safe mode and shut down for a while.
Newer houses should have the microwave on a dedicated circuit and should not have this problem - I say should not because electricians can make mistakes too.
You can try to trip your microwave circuit and see if anything else stops working. If so, that is likely why your microwave is falling into a safe mode - it is not getting enough juice.
If you have an older home (pre 1995), try to find what else is on your microwave circuit by tripping the breaker as listed above, then not using the other appliance when using the microwave.
Good luck.
Mar 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Loss of all power when trying to cook/defrost
The cost of repairing the micro wave will out cost the replacement value. If its new then use gaurrantee for replacement
Sep 03, 2009 | Microwave Ovens
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Timed Power Loss
It sounds like your magnetron is failing, but generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Apr 28, 2008 | Whirlpool MH1150XMQ Microwave Oven
JVM1650SH01
your problem most likely is in your door aligment there are 2 arms that need to close some door interlock switches inside the unit next time press in on the door hold it and try to start or push down on the door after it is closed and try to start it
Jan 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Sep 07, 2007 | Westinghouse WST3504 Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
194 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
