Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Panasonic PT-53WX54 My Panasonic t.v. won't stay on. It'll turn on for about 2 seconds then turn automatically off. The first problem that I had with my t.v. was that the color convergence got all screwed up, then it wouldn't stay on for more than 2-3 seconds after I'd press the on/off button. Can anyone tell me what's going on with my t.v.?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
You have defective convergence amps and should be replaced by qualified tech....john
Posted on Sep 11, 2007
SOURCE:
Keeps turning off and red light is blinking 3 time
If it is Panasonic PT-53WX54 rear projection tv then 3 times red light blinking indicates problem of convergence output chips failure in tv that need to be replaced to solve its problem.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you more helpful info OR call local tv repairman to replace convergence output chips tin tv.
Thanks.
Dec 30, 2010 | Panasonic PT-53WX54 53" Rear Projection...
MY PT-53WX53G turns off when powered on. The
Thats the error for convergence failure. Heres a link to the repair kit for your model which contains the parts and the CD with detailed instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Jul 06, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 06, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Picture Stretch on Panasonic PT-53WX54
Usually this is an indication of a failing capacitor in the vertical circuit. Have those been checked? I would look for 100ufd caps in the vertical circuit. Check with the tech.
Dan
Jun 02, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic pt-53wx54 53inc
Circuit problems, -- consult pro/tech
Apr 21, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Turning off closed captioning
You should be able to turn off caption from remote. Go to menu for this
Dec 12, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Please Help!!
convergence amp, but you will need to replace return resistors also. And maybe fuses in the same area.
Dec 06, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-53WX54 What is that popping noise?
A loud popping noise, like a sharp "snap!", is usually caused by high voltage arcing. Somewhere in the high voltage system an insulator may be cracked or loose, such as the plastic around the flyback transformer or one of the rubber cups on a picture tube. When the high voltage arcs, it momentarily drops and the picture could go out for a split second. High voltage is dangerous in projection sets so allow a qualified tech to service it for you.
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Convergence
covergence amp ic"S need to be replaced.
Aug 16, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
99 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
