Question about Creative Labs PC-Cam 600 Digital Camera
Resolution has lines in the 320x240 format
My pc cam 350 has visible horizontal lines in the 320x240 format and sometimes the colors change constantly and then sometimes freezes entirely. Also, sometimes there is no problem at all with crisp resolution and then....poof the resolution reverts to the lines again. Thank you so much
    Champion:
  • 217 Answers
Try to relocate your cam away from monitor, speakers or from pc. there maybe interference coming from these units. you may also try moving the cam cable and check for loose or intermittent connections. try removing/ reinserting the cable several times, this will gonna clean the pc to cam contacts
Posted on Sep 10, 2007
SOURCE:
Only sounds i hear when i play movie in my 5310 NOKIA MUSIC EXPRESS i can't see any video of the movie, what is the main problem of my cp?
at my experience your nokia 5310 not support your video codec but only support sound codec, for you know that video have two codec that is sound codec (mp3, aac, wav) and video codec (mp4 mpeg, H263, H264)
the other reason that you can play video is your video resolution is too big for your nokia 5310, nokia 5310 only support video for maksimum resolution is 320X240 pixel
i suggest you convert your video to video format that support your phone video codec and change the resolution to 320X240 pixel first before you download and play with your phone
i hope this helpful
thank you for using fixya
Feb 08, 2011 | Nokia 5310 Cellular Phone
Video in MP4 Format with resolution more then 320*240 is not working on my Nokia E63.. please suggest me solutions for it.
the max resolution video that can work at E63 is maximum 320X240, if you want to play video with resolution above 320X240 it will not recognized and not supported, try to converted video that resolution above 320X240 to resolution 320X240 first, use software video converter like IMTOO or another software you like, if you was convert try to play video that has 320X240 with your phone
it will work
i hope this helpful
Feb 04, 2011 | Nokia E63 Cell Phone
I have a Sony vio model PCG-3E2L laptop computer, the problem I have is my laptop screen is getting a horizontal fine line at the bottom one inch above the line is of red color but color changes from...
  1. It smees your LCD is faulty.
  2. connect your laptop to a external monitor. Check if lines are visible or not.
  3. if no line are visible then need to change your LCD.
  4. for changing better to contact service centre.
  5. you can look for used LCD, which will be cheap.
Aug 21, 2010 | Sony VAIO PCG-TR3AP1 Notebook
How do i put videos on my gogear
GO GEAR VIBESMV128 x 128, 24 fps
And there is free sofware to convert it
http://www.soft29.com/freeware/smv_converter.htm
GO GEAR MUSE
MPEG4 SP/ASP Upto D1 resolution, 30 fps, bitrates up to 4Mbps in .avi and .mp4 containers
MPEG4 AVC/H.264 BP Upto VGA resolution, 30 fps, bitrates up to 1.5Mbps in .mp4 containers
RMVB VGA resolution, 30 fps, bitrate upto 1 Mbps in .rmvb container
WMV9 VGA resolution , 30 fps, bitrate upto 1 Mbps in .wmv container
GO GEAR OPUS
MPEG4 SP Upto 640kbps in avi format, 320x240 , 30fps (Other formats supported by using provided converter software)
WMV9 Upto 512kbps, 320x240 , 30fps (Other formats supported by using provided converter software)
GO GEAR ARIA
SMV220 x 176, 24 fps
Nov 10, 2009 | Audio Players & Recorders
Horizontal lines and color problems?
this could be a format issue. When you change the channel do the lines go away ? If so try to go into the cable box (assuming you have a cable box) and reset your formats and exclude the format causing the lines.Make sure if your using component cables all colors match up.If this does not fix it replace your component cables/hdmi.All else fails unplug your TV wait 5 min. and plug it back in. Hope this works for you.
Jul 08, 2009 | Dynex DX-LCD32-09 LCD TV
Cant get utube to publish my tenminmixes in full
Youtube imposes a maximum limit of 10 minutes duration for each video and 100 MB max file size. Since your vids are under the 10 min limit, you should look at the file size as the offending party. If it is over 100 MB, thats the problem. To reduce the file size you need to understand what a CODEC(COder-DECoder) is and how CODECs can be used to make video files smaller for uploading to Youtube. The file you want to up-load has two parts, audio and video, Each part uses a different type of codec to encode and save the "movie" you created with your video editing program. The most common and efficient video/audio codecs used on Youtube are MPEG-4 and MP3. If your video app is not set to encode audio to MP3, you are probably encoding the audio into a raw uncompressed WAV format (pronounced wave). Uncompressed WAV files are very large compared to the MP3 format. Setting the audio bitrate can be confusing. To keep it as simple as possible, I suggest setting the Bitrate to 128 kb/s STEREO if the video has music or 96 kb/s MONO if it is just people talking. Set the Sampling rate to 44100 Hz (or 44.1Khz) AAC is another Audio format. The same sampling and bitrates apply. The next thing you want to look at is the Video resolution and type of file you are saving/recording to. Since you are recording from a webcam, you may be using a propriatary codec that came with the camera. If this is the case, then you need to let me know what brand camera and software you are using. Most video cameras, including web-cams, use non-proprietary formats that can generate very large (but high resolution) files. For example: .avi & .mpg. You want to record at the highests resolution you can, BUT, you will save it later to a lower resolution compressed file. Many webcams can record at 800x600 and 640x480, but the file you will save for Youtube may be 320x240, 480x360 or 640x480. The higher the numbers the higher the resolution, but also the larger the file size. Also, the more motion there is in a video, the larger the file will be. So, if you have a lot of action and need to "squeeze" it in (compress) the video, use a lower output resolution (320x240). If it is an interview type video, where the background stays the same, you may get away with a higher resolution (640x480) if you want a sharper image. When recordings from the camera are saved as .avi, .mov or .mpg, you will have to change the output format in your video editing program to mp4 (H.264) format. You may also be able to set your webcam to record directly to the mp4 format, which would be ideal, if you do not plan on editing your video. Then you can simply record and upload. The bottom line. ------------------ When you are done editing your movie and are ready to save it. Find where you can set or change output options in the editing app. Set the audio and video bitrates and resolution to those best suited to your needs. Change the output type to MP4, aka H.264 (for video) and MP3 or AAC (for audio). Click save, wait a bit, upload your video to YT for the world to see and revel in the glory of being a producer. Scorpio
May 09, 2009 | YouTube Videos
How do you load movie on to the sylvania 4gb mp3 player
This is often a problem among mp4's but the solution however is simple.
The movie needs to be in AVI format, of course, but there is also the hassle of having the right resolution.
Depending on the size of the screen determines the maximum resolution, if the max is peak, then the video becomes unplayable.
Your mp4 settings are as follows.... 2.8-Inch TFT 260K True Color 320x240 Pixels
This means that when you are converting your avi movie, make sure that the resolution is set to 320x240 for maximum viewing and quality.
Hope this fixya up <(^_^)>
Apr 19, 2009 | Sylvania SMPK8854 Digital Media Player
Heavy white lines accross the screen
change the ram and viedo card agian
Jun 07, 2008 | Computers & Internet
Awfull colors and very dark at 320x240
hello JareX Perhaps as far as I can tell you that your screen does not suppeot this resolution
Jan 20, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Creative Labs PC-Cam 600 Digital Camera Logo
59 people viewed this question
Top Creative Labs Cameras Experts
David Hoff
ray gallant
ray gallant
Tony Parsons
Tony Parsons
Are you a Creative Labs Camera Expert? Answer questions, earn points and help others
