Question about Intel Pentium 4, 2.8 GHz (bx80546pg2800e) Boxed Processor Upgrade
Processor overheating hi my computer is starting up ok then after 30 seconds keeps shutting down.my processor fan is working but processor is very hot to the touch. please help as i don't know if the processor is broken or is something less drastic.
  • 2 more comments
  • Anonymous Nov 06, 2007
    IS THERE ANYONE WHO CAN HELP ME??????????????????????
    hi,
    i have intel  dual processor 3.4ghrz intel board. These days we used to enjoy winter season but my system is
    facing the termal problem (overheating). when i check the solution and
    someone told me to use the thermal paste but still its same as after 1 min its
    getting sutdown so can you plz help me. i will be very great full if you will save me and my processor.
    thanks
    9891971895
  • anchal Nov 13, 2007
    hi my processor is intel pentium 4 clock speed 2.4 Ghz ...it shuts down any time due to overheat....what do i do....?
    katiyar.anchal@gmail.com
  • cyberlan Apr 25, 2008
    My computer keeps shutting down after starting it
  • vprejul Aug 30, 2008
I had the same issue - computer would work until the CPU got too hot and would just turn off - no shut down - I took the computer apart and found that dust had built up in the heat sink and there was absolutely no air flow - I used a small screwdriver and a vacuum cleaner to **** the debris out from around the fan and heat sink and the computer seems to run fine now - I know this a simple solution to what may prove to me a more complex problem but it seemed to work for me - good luck
Posted on Apr 26, 2009
Sorry, but were having the same problem..
mine is Intel P4 2.8.. and also it slows down
when i opened 2 or 3 windows..then shut down..
damn!!
Posted on Mar 09, 2008
    Problem Solver:
  • 9 Answers
Do you have standard CPU cooling? maybe you can try to get better cpu cooling. Thermalright has great CPU Cooling. Min is idle 20 degrees and full speed working 35 degrees
Posted on Feb 13, 2008
Not a solution but my processor won't power on. Have had Power? replaced, no luck, mother board check, told fine, still won't turn on. Help please!!!!!!!
Posted on Jan 23, 2008
In your bis change the temp settings if this does not solve the prob then switch off the temp settings
Posted on Oct 08, 2007
The pc is shutting down because is overheating. Try to look if your cooler is placed the right side. If you look at the base of cooler, there is one stair, that must fit on socket. Or try to use new paste, or lower the Voltage of the CPU. Monitor the heat of cpu by some program. Maybe cpu is broken...sorry for my english, it is not my native language:D
Posted on Oct 07, 2007
    Novelist:
    Champion:
  • 231 Answers
Hi have you cleaned the heatsink? Also replace the paste on the CPU, also you could try installing an extra fan on the case to increase air flow. Also check that your RAM is seated properly and any other chip and card on your board is firmly plugged in. If all this fails replace your CPU. Regards mistyman
Posted on Sep 10, 2007
Ok i read some forums on the web about the amd am2 5800+ processors and it says nothin about them overheatin.. so down on the forum it said that when the cpu shut off from gettin to hot to feel the...
try this, open case then plug off processor cooling fan, then plug off processor, clean it, then plug on again the processor and cooling fan, if need take more fan on your pc then turn it on, if still like that it mean you must change your processor
Jan 23, 2011 | Abit Fatal1ty AN9 32X Motherboard
Computer shuts down on its own
Most likely when a computer shuts down on its own it is because the computer processor or power supply is either overheating or is under powered.
Feel with your hand around the computer case and back of the power supply (has circular fan usually/ on off switch/ and a plug goes into it)
If it is very hot you will have found your answer.
Did you just install or upgrade a processor? If so you may need to check to make sure that there is thermal compound (artic silver, etc) between the processor and heat sync. This can cause overheating and sudden shut downs. If not move on
Is your computer in a small enclosed area? Try moving it to an area with more area for ventallation and cooling.
Do you have adequate cooling/fans? are they working? if not check power cables and may need to replace the fans or install more. You can buy and install case fans pretty easily
DUST. Are the fans and imputs dirty? Keeping them clean will keep the computer running cooler and help lower temperature and avoid shut downs. If your fans/imputs are dirty remove dust by using a can of compressed air, a vacuum made specifically for pc/electronics. or you may wipe them down with rubbing alcohol and a dust free cloth.
This should help Anthony
Jan 18, 2011 | Dell Inspiron 530 Desktop Computer
Computer keeps shutting down and states "computer
Did u put the FAN to the right CPU FAN board connection? or Align ur heatsink to the processor, procie might have been overheating 'cause the heat sink didn't touch the procie!
Nov 09, 2010 | Intel Motherboard
Optiplex GX520 will not power up, system initially starts but after a few seconds it will shut off and attemt to power up again. Power supply was swapped out with a known working unit, still the system...
If after swapping the Power Supply the same problem persist, You have probably done all you can for this machine.
If the CPU Fan only spins for less then 5 seconds, wait 30 minutes and try again. If it spins the same amount of time, I am afraid that the Motherboard is most likely damaged.
IF it spins longer, there is a possibility that the CPU Grease between the CPU Fan and the Processor is Dried Out and You Processor is Overheating, Thus Shutting Down. It will need to be Cleaned and Replaced.
Be careful when removing and Replacing the Fan and Processor to NOT BEND the Processor Pins. It will only FIT ONE WAY.
Please update Post if you need Further Assistance.
Hope this Helps!
Dec 22, 2009 | Dell OptiPlex GX520 PC Desktop
Computer keeps shutting down. It will start up and sometimes work for a while then shut down unpromted. Or if I start it, the computer will just keep shutting down and restarting for no reason. I can get...
That sounds like either a graphics problem or more likely a memory problem. Try taking out a couple sticks of RAM or leave just one in and try that.
Nov 09, 2009 | Computers & Internet
Power to the mobo
Without having the specs on the motherboard or knowing how old it is, it's difficult to say if it is beyond repair. Although my experience with computers shutting down that quickly while attempting to boot have been a problem related to processor overheating. Processors get very hot within seconds of powering on. If the processor cooling fan or the thermal paste is not working as intended the system will shut down quickly. You may want to check those two possibilities before purchasing a new motherboard.
Nov 19, 2008 | FIC AM 37 Motherboard
Laptop keeps shutting down
Check the key hybernation
Start >> Control Panel >> Power Options >> Hybernate (must be UNCHECKED)
See another features.
Check your bios at CPU to check if overheating feature is activated,
check the temperature of your CPU
Oct 29, 2008 | NEC Versa Premium Notebook
Keeps Shutting Down
First, start by taking the fan and heat sink out and cleaning them. Dust build up can cause overheating. Also check the fan for hairs or carpet fibers that have gotten wound in it, I've had fans stop working due to this. Then put it back together and check to see if the fan is coming on and running in regular intervals. If it's not it will need replaced. If it is, then there may be a malfunction with the processor or a short on the motherboard.
Jul 07, 2008 | Toshiba Satellite A105 Notebook
Computer Shuts down
Well your processor may be damaged..
dont worry may be it is not damaged so what do you do is that open the cover of your computer.... Then start it and keep the cover opened making sure that you can see the processor fan running...
See that if the processor fan is running...
then with the help of a torch see that may be the fan is being restricted or it is moving slowly.
this slowness of the fan heats up the processor and makes it shut down you PC
if the is running slowly take out the fan using the user guide of the processor and then lubricate it with motor oil.
it IT Does not work then there is a problem with your processor so please check by placeing another supportive processor and check it!
Dec 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Acer Aspire Shuts down when I play my on-line game
A notebook can only shut down if the processor is getting HOT that is by itself. I can timagine its a virus because you said you formatted it?. You keep maintaining that it keepsshutting down. to me thats the CPU because its getting too HOT> How to fix is to check to see if the fan is ok the one on top. Even when it glogs up the fan can always clear it ......may be a faulty fan check it...
Sep 13, 2007 | Acer Aspire 5100-5022 Notebook
Intel Pentium 4, 2.8 GHz (bx80546pg2800e) Boxed Processor Upgrade Logo
318 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
